Returne line collapsed
/ Returne line collapsed #1
Ortega
Hi my low pressure hydraulic returne line collapse every time I start any help thanks
/ Returne line collapsed #2
Welcome to TBN
It would help responders if you'd reveal type & model of machine you're inquiring about that suction hose is collapsing.
/ Returne line collapsed #3
Yep, you are pulling a vacuum in the return line, and probably in the hydraulic reservoir as well. Here are the common causes:
First check your trans/hydraulic fluid to make sure it is not contaminated with water.
If it is, the oil on the dipstick will look like chocolate milk instead of clear oil. Contaminated oil gets stringy and clogs filters.
Next check the vent on the trans/hydraulic reservoir. Your hydraulic reservoir is vented - they all are - and collapsing the return line will also happen with if that vent is clogged.
But if those quick checks show OK then the most common cause is that suction filter between the hydraulic tank and hydraulic pressure pump is clogged & not feeding as much as the pump would like to draw. Your power steering is probably jerky and the 3pt or loader slow as well.
Not sure about your tractor, but most makes have the same two filters: a cleanable screen in the hydraulic outlet from the reservoir and also a spin-on type filter in the line to the pump. Clean the one and replace the other.
One of those things should do it. Might as well do them all.
good luck,
rScotty
Thank you I will. Check the filters and the oil this coming week
/ Returne line collapsed #5
From rScotty: "Your power steering is probably jerky...." Ah...... My 2210 every now and then will have a skip in the power steering. The fluid is clear and at the proper level. Now I have to figure out where return screen is.
/ Returne line collapsed #7
Yep, your 2210 has the same filter setup. If not that, it could be that the steering box needs some seal & bearing work. But that is easy enough to do - just not as easy as filters.
HARDEE 4R SPRAYER (A63291)
HARDEE 4R SPRAYER...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
Set 4 - 10-16.5 tires on wheels for bobcat (A61572)
Set 4 - 10-16.5...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
