Retrofit Cruise Control
   / Retrofit Cruise Control #1
Arcane
SE MA
Kubota B7800
Is it possible to add cruise control to a tractor with hydrostatic transmission? Is there a kit? The tractor is a JD 4115. When I bought it I didn't think I'd be spending so much time at constant speeds (mowing, spreading, etc.)
Thank in advance.
RK
   / Retrofit Cruise Control #2
Does this unit not have a stick throttle? How do you accelerate, I realize you can go faster forward/reverse by how much you push HST pedal, but I would think engine speed would be controlled by throttle.
   / Retrofit Cruise Control #3
I think he's looking for a kit to hold the hydro pedal not the throttle control.
If your rig had cruise as an option I'm sure it could be added now. Most are just a simple electromagnet device.
There is a stick throttle that controls engine rpm, but transmission speed is controlled by the HST pedal. Cruise was not an option when I bought it a few years ago, and the dealer says no Deere retrofit kit. I was just wondering if there is an aftermarket kit.
They are electromagnetic, eh? Do they work on the pedal itself (i.e., holding it down with a strong magnetic pull), or on some dog inside the transmission? If the latter, probably would need to be transmission-specific.
Thanks for the info. Cruise is on my must-have list for the next tractor.
   / Retrofit Cruise Control #5
Thank in advance.
RK
My 4110 has mechanical CC standard, was not an option. I thought the 4115 was the same? Aren't there 2 red handles under the steering wheel? the one on the left is the parking brake, and the one on the right is the CC...
Um,...red handle, red face. :eek:
   / Retrofit Cruise Control #10
No problem! Do you have the manual for your tractor?
The real travesty of this story is that you asked your dealer, and he said there was no "retrofit" kit. He did not know is was already on there:eek:
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52748)
Neckover GL24-2-7K...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2015 Kia Sorento AWD SUV (A50324)
2015 Kia Sorento...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
