Retractable (electrical) Extension Cord Suggestions?
   / Retractable (electrical) Extension Cord Suggestions? #31
I'm looking for 50 feet, 12g, want three plugs on the end of it. I don't care if they're lit or not
Which end do you want with three plugs?
Fifty feet! How high are your ceilings?
   / Retractable (electrical) Extension Cord Suggestions? #33
   / Retractable (electrical) Extension Cord Suggestions? #34
I've got one that I picked up from HF about 10 years ago, 40 or 50' idk. 15A with a breaker near the 3-plug end.
It's always needed help retracting; I figured it was just the cheap HF stuff and kept it.
I have it mounted above my shop's garage door such that I can use it inside or grab it from above the door when it's open and pull it out. Doesn't seem to mind if the door is closed on it in that position, either.
Occasionally I consider replacing it with one that actually has a spring...
lol, the Garage is 9' high. The question isn't how high is the ceiling but rather, how far out into the driveway do you intend to use it?
I'm currently using a 12g 100' that is plugged into the interior wall. I'm trying to get away from 100' (hence the 50) and I'm going to run a power line down the wall to very near the garage door.
Now, I'll be able to pull outside to put battery charger on (while battery is installed on tractor or backhoe), use mitre saw, table saw.... jigsaw....router....
I might be wrong but I'm viewing this as a net less stressful (electronically speaking) situation than doing the same with a 100' cord.
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
