Retaining Wall Build with Landscape block
   / Retaining Wall Build with Landscape block #1
ktm010
Upstate NY
I did this project this past fall with the help from my JD955. The project showed the limitations of the #7 hoe which I've had for about 1 year or so, also used the newly build forks with SSQA which I built from Ideas from this site and help from the members, Thank You!!.
More pics
More pics
All done except for planting some grass and shrubs. I had some pavers from an old sidewalk I replaced a few years back. Laid them down for a nice area in front of the doors
   / Retaining Wall Build with Landscape block #5
Wow, looks great.
Just throwing this out there, used all natural stone for this wall, and water drainage or run off to keep water off the driveway
   / Retaining Wall Build with Landscape block #7
Looks great!
Where did you get the blocks?
   / Retaining Wall Build with Landscape block #9
Wow, why the huge batter? We installed for 8 years and never saw more than a 1/2 inch batter called for on a small wall like that. Although now that I look closer thats not a pin system is it, looks like lipped units? Hmm never used those. Nice job though.
   / Retaining Wall Build with Landscape block #10
Much better than the old landscape timbers and you built a good foundation for it and the drain pipes behind the wall should go a long way towards keeping the hydrostatic pressure from undoing your hard work.
Pavestone www.pavestone.com uses the lip system and I believe they have different batter angles depending on the block style.
2020 Terex RL4 Towable Light Tower (A53421)
2020 Terex RL4...
Fiberglass Cow Statue (A55218)
Fiberglass Cow...
2013 Honda CR-Z EX Hatchback (A53424)
2013 Honda CR-Z EX...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55301)
Adams Load Out...
CAT Skid Steer (A50322)
CAT Skid Steer...
1270 (A50490)
1270 (A50490)
