Retaining Wall Build with Landscape block
   / Retaining Wall Build with Landscape block #1
ktm010
Upstate NY
I did this project this past fall with the help from my JD955. The project showed the limitations of the #7 hoe which I've had for about 1 year or so, also used the newly build forks with SSQA which I built from Ideas from this site and help from the members, Thank You!!.
More pics
More pics
All done except for planting some grass and shrubs. I had some pavers from an old sidewalk I replaced a few years back. Laid them down for a nice area in front of the doors
   / Retaining Wall Build with Landscape block #5
Wow, looks great.
Just throwing this out there, used all natural stone for this wall, and water drainage or run off to keep water off the driveway
   / Retaining Wall Build with Landscape block #7
Looks great!
Where did you get the blocks?
   / Retaining Wall Build with Landscape block #9
Wow, why the huge batter? We installed for 8 years and never saw more than a 1/2 inch batter called for on a small wall like that. Although now that I look closer thats not a pin system is it, looks like lipped units? Hmm never used those. Nice job though.
   / Retaining Wall Build with Landscape block #10
Much better than the old landscape timbers and you built a good foundation for it and the drain pipes behind the wall should go a long way towards keeping the hydrostatic pressure from undoing your hard work.
Pavestone www.pavestone.com uses the lip system and I believe they have different batter angles depending on the block style.
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
CATERPILLAR HANG ON 71" WHEEL LOADER FORKS (A51406)
CATERPILLAR HANG...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
FAKE (A52472)
FAKE (A52472)
