Restoring lost prime in hydraulic pump?
/ Restoring lost prime in hydraulic pump? #1
Gitche Gumee Kid
Bronze Member
NW WI
IH 284
A member suggested that my lack of hydraulics is from loss of prime .
How do you restore?
TIA
GGK
/ Restoring lost prime in hydraulic pump? #2
Use about 5 lbs of air pressure in the reservoir using a rag or a V cone plug.
If you have a sump screen, clean that first.
Many thanks J _J. I'll get right on it and let you know.
GGK
J_J,
So far I have been unable to locate a sump screen. IN my search for the a screen I removed the drain plug on the bottom of the reservoir. I thought maybe there is a screen at that point. None found but I did see what appears to be a ball bearing about 3/8" in diam It flowed out with the 1st gush of hydrl fluid. Did this break off somewhere up stream?? Is this related to my problem of no hydraulics?
GG
/ Restoring lost prime in hydraulic pump? #5
It is hard to say where that bearing came from, could be from a check valve assembly.
I would recommend a parts manual. You probably need one anyway.
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
ALKOTA ELECTRIC HOT PRESSURE WASHER (A64276)
ALKOTA ELECTRIC...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
KMC 6-36 (A64119)
KMC 6-36 (A64119)
more info coming soon (A61569)
more info coming...
2019 Volvo VNR64T T/A Sleeper Cab Truck Tractor (A61573)
2019 Volvo VNR64T...
