Restoring lost prime in hydraulic pump?
/ Restoring lost prime in hydraulic pump? #1
Gitche Gumee Kid
NW WI
IH 284
A member suggested that my lack of hydraulics is from loss of prime .
How do you restore?
TIA
GGK
/ Restoring lost prime in hydraulic pump? #2
Use about 5 lbs of air pressure in the reservoir using a rag or a V cone plug.
If you have a sump screen, clean that first.
Many thanks J _J. I'll get right on it and let you know.
GGK
J_J,
So far I have been unable to locate a sump screen. IN my search for the a screen I removed the drain plug on the bottom of the reservoir. I thought maybe there is a screen at that point. None found but I did see what appears to be a ball bearing about 3/8" in diam It flowed out with the 1st gush of hydrl fluid. Did this break off somewhere up stream?? Is this related to my problem of no hydraulics?
GG
/ Restoring lost prime in hydraulic pump? #5
It is hard to say where that bearing came from, could be from a check valve assembly.
I would recommend a parts manual. You probably need one anyway.
2019 John Deere 4044M (A62177)
2019 John Deere...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
