Restore finish on for 3910 tach
   / Restore finish on for 3910 tach #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
The glass on my Ford 3910 tractor tach is very hazy from being out in the weather. Is there a way to restore the finish?
Bump bump
   / Restore finish on for 3910 tach #3
I don't know what the lens is made of...glass, plexi-glass, etc... But i've had good luck polishing non-glass lenses and windows with a product called Plexus. I've also used Meguiars Mirror Glaze with good results on various lenses and things.
Good luck!
Update
Well i took the tach apart and it was very easy. There was some dust inside so i cleaned it as good as i could. Then i took the polycarbonate lens and started the polishing process with the 3M lens cleaner kit i bought. Somewhat of a job as it was in very rough shape. Totally etched out and very yellowish. So bad it was hard to read tach. So after i went through all the levels of sandpaper and polishing it looks like new. Now i'm dealing with the black plastic bezel. It is very tarnished and faded so i have purchased a can of spray paint for plastic. I will post pics once I'm done but so far it is looking awesome.
Here is a picture of the finished Tachometer. I wish i would have done a before and after.
   / Restore finish on for 3910 tach #6
Looks good as new. Nice job.
Thanks. I still cant believe it turned out this nice. I hope this can help others in the future.
   / Restore finish on for 3910 tach #8
That looks great, Good Job!
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
2013 Bobcat T180 (A47477)
2013 Bobcat T180...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
