Restarting My '70 Nova Project
   / Restarting My '70 Nova Project
Our cams are almost identical.
Mine has a bit higher lift but that valve event should not be impeding your fuel atomization at lower rpm’s.
Did you try the medium cam setting?
My stall converter is 2800 with 3.91’s out back but yours is a stick right?
As I recall, you measured vacuum and you’re producing sufficient amounts.
I wonder if the electronic position sensor may be wonky on your unit? Your idle would be getting higher if it was creeping.
Should be at zero.
Before we jump to that conclusion, try the mid cam setting.
I tried all three cam settings, no difference.
I have a manual five speed transmission.
I'm running an MSD distributor that connects to the MSD Streetfire ignition box, and I have checked the timing and it's at 12° BTC. It has 20° of centrifugal advance that is all in by 3,000 RPM. Timing is steady, not bouncing around.
I forget what the manifold vacuum is at idle, but it was at an acceptable reading when I checked it.
Just in the last couple of days, it had started backfiring when shifting. It has never done that before. Many times that is an indication of an exhaust leak and/or lean mixture. I've checked and haven't found nor heard any exhaust leaks.
I'm going to call tech support tomorrow, I'll report back on what they say, if anything.
   / Restarting My '70 Nova Project #852
I’m sorry if you covered this already but do you have wide band O2 sensors installed? Can you log data to a laptop? It’s tough to compare a newer car to yours but with my newer Challenger and its tuner I can log data to a laptop while driving. If you have that ability you can maybe see the problem as it happens. There might be someone with a dyno in your area that can help also.
   / Restarting My '70 Nova Project #853
The Snipers do have output parameters but his is an older unit and thus limited as to fuel table input.
I have the single 02 sensor installed that came with the EFI unit. I think it is working properly, as it seems to track changes in AFR quickly, as it is displayed on the hand unit. No, this unit does not have data logging, that's one of the questions I asked the tech when I called MSD yesterday. The hand controller has a USB port, but he said it is a dead port and has no function. I would guess it was used to install firmware at the factory, as I hooked my laptop to it, and it didn't recognize the connection. It did, however, disable the hand unit, so that no data was being shown and the joystick control didn't work. Being able to log data to see just what is happening would be a great tool, but it just isn't possible on this system.
As far as dyno tuning it, with the few parameters that are available to modify, I don't think that would be helpful.
The one thing that he felt was a major problem was that I have a hard line running most of the way from the tank the the EFI unit. It does state in the installation manual that you should only run a soft line, like was supplied with the kit from the pump to the EFI unit. He said that the pulsations from the pump that is powered by a PWM driver in the EFI unit could be what is causing the erratic behavior of the system. That could be so, but my question was that it had run just fine up to this point with the hard line, so why is it suddenly a problem now, after running it for over 400 miles? He had no explanation for that.
When I installed a FiTech system on a friends Charger, I ran SS braided line from the tank to the EFI unit, and he has had no problems with that at all, and he is using the same in-tank system that I'm running. I don't have enough rubber line to run it all the way, but I do have plenty of the SS hose, so I'm thinking of running that from the tank to the EFI unit and see if that changes anything. And if I didn't mention it before, the pump is in my tank, not externally mounted.
I've decided that if I can't get it straightened out, this winter I'm going to switch to a different EFI setup, either a FiTech or Holley. I just want it to run correctly and not have to fuss with it all the time.
I have it jacked up on jack stands and today I'm going to pull the had lines off and start running the SS hose. That's going to be fun, but hopefully it'll solve the problem.
Stay tuned.
There is no way on the unit I have to modify the fuel tables, I asked the tech about that, and he said no, there isn't.
   / Restarting My '70 Nova Project #856
OP: how long has this project been going on?
   / Restarting My '70 Nova Project #857
In your shoes I’d change out the fuel line not because of pulsation but to eliminate any problem with blockage. I’d even take down the pump for inspection.
Secondly, you’ve built yourself a fine car and sunk a lot of time and money in it.
I think both the car and you deserve only the best so do it up with a new fuel delivery system if you need to.
2018 HINO 268  NON CDL 26FT BOX TRUCK (A54607)
2018 HINO 268 NON...
STRICKLAND CASE 621D WHEEL LOADER FORKS (A52705)
STRICKLAND CASE...
2008 JLG 2630ES ELECTRIC SCISSOR LIFT (A52705)
2008 JLG 2630ES...
2016 NISSAN VERSA Sedan (A53424)
2016 NISSAN VERSA...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2019 John Deere XUV560E Utility Cart (A55787)
2019 John Deere...
