Restarting My '70 Nova Project
/ Restarting My '70 Nova Project
I wish I had the '69 SS396 L78 375HP Nova I had beck in the early 70s. I had to sell it and buy a more family friendly car when I got married.
/ Restarting My '70 Nova Project #842
Glad to see you are getting a chance to enjoy your beautiful Nova. I was at a car show last week-end and was wondering how your summer was going with it on the road.
/ Restarting My '70 Nova Project #843
Been putting some miles on the Nova, and the small tach I installed in the cluster is difficult to read and not accurate. I have an Autometer pod tach, like the venerable Sun Super Tach of days gone by, so I decided to mount that on the right side of the steering column. Fortunately, I connected the in-dash tach to the wire harness with a three pin Deutsch connector, just in case this situation arose. So I installed a connector on the Autometer tach wires disconnected the old tach, and connected the new one. I had to take the steering column loose to be able to get to the connectors, but I was able to switch the connection and put it back together pretty easily. I connected the internal light to the power wire, so it's on all the time, rather than pull the cluster out and run another wire just for that.
Started it up, and it agrees with the digital readout on the EFI hand set as closely as you can determine on an analog scale.
It was a nice day, so I went for a 50 mile cruise around the area, burning up some of that Speedway 93 octane gas. Next tank, I think I might try running the mid-grade gas in it, as long as it doesn't ping under a load.
I've been fussing with the EFI for a couple of weeks, as it developed a low RPM bog that was getting worse, it was leaning it out, and you had to feed it throttle really slow, and would then take off. It was really annoying taking off from a stop. Tried adjusting AFRs, accelerator shot, power valve setting, ignition timing and checking for vacuum leaks, all to no avail. I finally reset it back to factory defaults, and it's much better now. I think it just needs to be kept above 1500 RPM due to the fairly aggressive cam, it doesn't like being lugged down.
With the overdrive transmission, I can cruise 60 MPH at 1900 RPM, which is really nice, witch cuts down on noise and fuel consumption, so I'm really glad I went with the TKX with the .68:1 fifth gear.
I still have to put the new upper A-arms on and get it realigned, but I've been procrastinating about doing it for no good reason. Should be pretty easy, I just need to knuckle down and get 'er done.
Great to hear you’re enjoying your ride! What kind of compression are you running? As far as your issue, I personally don’t like that it was getting worse, I would call the tech support and pick there brain 🧠! I think what you did was good, but just a band aid in my opinion, no disrespect!!! I think you are extremely detailed oriented👍🏻
The 434 is running 10.5 to 1 compression.
Yes, I'm going to call tech support next week, about the problem, and also a couple of other questions. One of the problems is that I bought the EFI system in 2012, and they only ever put out one update for the software several years ago. They have since been acquired by Holley, and they push their EFI systems rather than any real updates to the MSD products.
/ Restarting My '70 Nova Project #845
Do you have a self contained efi system such as a Sniper?
Your cam size should have little to do with it.
I agree to you having a low end bog caused by lack of low rpm fuel.
The self contained Edelbrock or Sniper have fuel table adjustments at any rpm.
Something is impeding your fuel flow at low rpm so I assume fuel pressure is ok?
There is a setting for the cam type, Stock, Medium or large and I have it set on large, as it has over 230° of duration.
The fuel pressure fluctuates a lot. It's not a problem with the pump, as I can change the setting so that the pump runs constantly, as when set up as a system with a pressure regulator and return line, and it will develop well over 100 PSI.
Tomorrow I'm going to plug my laptop into the handset and see what that shows. I can't find any info on what program to use to access the tables or look at the data logs, everything I can find is for the more recent Holley Sniper systems. That's one of the questions I have for tech support.
/ Restarting My '70 Nova Project #847
If you’re at .50 with 230 duration with your engine cubes, whether intake or exhaust, I would consider that a medium cam.
I have 236-242 in a 408at .50 and would consider that medium.
Lsa at 112.
Lsa at 112.
That's pretty much the same as the cam I have in the 434. The instructions for the EFI say that over 230° to use the large setting, but I have tried it on both settings with the same result.
The cam card says 239° IN and 246° EX with 112° LSA.
/ Restarting My '70 Nova Project #849
Our cams are almost identical.
Mine has a bit higher lift but that valve event should not be impeding your fuel atomization at lower rpm’s.
Did you try the medium cam setting?
My stall converter is 2800 with 3.91’s out back but yours is a stick right?
As I recall, you measured vacuum and you’re producing sufficient amounts.
I wonder if the electronic position sensor may be wonky on your unit? Your idle would be getting higher if it was creeping.
Should be at zero.
Before we jump to that conclusion, try the mid cam setting.
/ Restarting My '70 Nova Project #850
Well that sucks!!! May they still have someone on staff who can help you🤞🏻. I had a 351W 10 to one in my first race motor I ran premium 4(gl) to one gl 100 octane no pinging and got 2,500 passes before going to a 408W. Let me know about the phone 📱 call!!!
Should be at zero.
I tried all three cam settings, no difference.
I have a manual five speed transmission.
I'm running an MSD distributor that connects to the MSD Streetfire ignition box, and I have checked the timing and it's at 12° BTC. It has 20° of centrifugal advance that is all in by 3,000 RPM. Timing is steady, not bouncing around.
I forget what the manifold vacuum is at idle, but it was at an acceptable reading when I checked it.
Just in the last couple of days, it had started backfiring when shifting. It has never done that before. Many times that is an indication of an exhaust leak and/or lean mixture. I've checked and haven't found nor heard any exhaust leaks.
I'm going to call tech support tomorrow, I'll report back on what they say, if anything.
/ Restarting My '70 Nova Project #852
I’m sorry if you covered this already but do you have wide band O2 sensors installed? Can you log data to a laptop? It’s tough to compare a newer car to yours but with my newer Challenger and its tuner I can log data to a laptop while driving. If you have that ability you can maybe see the problem as it happens. There might be someone with a dyno in your area that can help also.
/ Restarting My '70 Nova Project #853
The Snipers do have output parameters but his is an older unit and thus limited as to fuel table input.
I have the single 02 sensor installed that came with the EFI unit. I think it is working properly, as it seems to track changes in AFR quickly, as it is displayed on the hand unit. No, this unit does not have data logging, that's one of the questions I asked the tech when I called MSD yesterday. The hand controller has a USB port, but he said it is a dead port and has no function. I would guess it was used to install firmware at the factory, as I hooked my laptop to it, and it didn't recognize the connection. It did, however, disable the hand unit, so that no data was being shown and the joystick control didn't work. Being able to log data to see just what is happening would be a great tool, but it just isn't possible on this system.
As far as dyno tuning it, with the few parameters that are available to modify, I don't think that would be helpful.
The one thing that he felt was a major problem was that I have a hard line running most of the way from the tank the the EFI unit. It does state in the installation manual that you should only run a soft line, like was supplied with the kit from the pump to the EFI unit. He said that the pulsations from the pump that is powered by a PWM driver in the EFI unit could be what is causing the erratic behavior of the system. That could be so, but my question was that it had run just fine up to this point with the hard line, so why is it suddenly a problem now, after running it for over 400 miles? He had no explanation for that.
When I installed a FiTech system on a friends Charger, I ran SS braided line from the tank to the EFI unit, and he has had no problems with that at all, and he is using the same in-tank system that I'm running. I don't have enough rubber line to run it all the way, but I do have plenty of the SS hose, so I'm thinking of running that from the tank to the EFI unit and see if that changes anything. And if I didn't mention it before, the pump is in my tank, not externally mounted.
I've decided that if I can't get it straightened out, this winter I'm going to switch to a different EFI setup, either a FiTech or Holley. I just want it to run correctly and not have to fuss with it all the time.
I have it jacked up on jack stands and today I'm going to pull the had lines off and start running the SS hose. That's going to be fun, but hopefully it'll solve the problem.
Stay tuned.
There is no way on the unit I have to modify the fuel tables, I asked the tech about that, and he said no, there isn't.
/ Restarting My '70 Nova Project #856
OP: how long has this project been going on?
/ Restarting My '70 Nova Project #857
In your shoes I’d change out the fuel line not because of pulsation but to eliminate any problem with blockage. I’d even take down the pump for inspection.
Secondly, you’ve built yourself a fine car and sunk a lot of time and money in it.
I think both the car and you deserve only the best so do it up with a new fuel delivery system if you need to.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
New/Unused CFG Industrial MX12RX Mini Excavator (A65583)
New/Unused CFG...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
