Required Photos of BX25D
   / Required Photos of BX25D #1
coveredbridge
The Real Central PA
BX25D, JD 820
BX25D was finally delivered today. Block heater is still on backorder. Was able to do a little digging today, though it was cold and the ground is pretty mushy. Pics at delivery.
Pics after I got it dirty. Also added the BXpanded bucket hooks.
   / Required Photos of BX25D #2
Looking good. I added the BX hooks as well. Check the springs occasionally. Mine sometimes pop up or wiggle loose. But I sure have gotten good use with them and a 20ft chain.
   / Required Photos of BX25D #3
Cool beans, I'm jealous
   / Required Photos of BX25D #4
Nice - the hooks are a nice add on. May have to order a set of those!
   / Required Photos of BX25D #5
I was going to get a set of those bucket hooks as well, but then my friend welded a receiver hitch on to the bucket, so now I just hook chains around the ball of the trailer hitch.
Congratulations on your purchase of a fabulous tractor. I have a BX 25 myself. By the way don't forget to get the bucket expander from BXpanded.com if you are going to use the front end loader for any amount of work carrying dirt, gravel, snow, etc. The bucket expander doubles the heaped capacity of the FEL.
   / Required Photos of BX25D #6
View attachment 366690View attachment 366691View attachment 366692View attachment 366693
View attachment 366694View attachment 366695View attachment 366696View attachment 366697
Hey! Just like mine..'cept for the tires...Happy tractoring!
   / Required Photos of BX25D #7
That looks good....I asked about a block heater for mine but my dealer said they don't have any real problem starting in the cold and talked me out of it....They had to order the deck so I would think if it was something they felt I needed they would have been happy to sell it to me. You are quite a bit north of me however...bet it gets colder up there then it does here. We will hit 0 once or twice a year but hanging in the 20's is about as cold as it gets here.
Real interested in the bucket hooks. I have been looking hard at them but just can't get my head around how they attach and stay on to the bucket. They would be VERY useful. I hate buying stuff without a real clear understanding how it all goes together.
Yours is just like mine, except for the thumb. I did the grapple thing and not the thumb. I had it in my quote and again the dealer said with one you really don't need the other.
We've been below zero several times here, but this has been a colder than normal winter. The desire for the block heater was based on the BX1500, which really had to be cranked to get it to start in cold weather if not preheated. The BX25D seems to start easier, so maybe a heater isn't needed, but I figured the few extra dollars was worth it for the convenience of cranking a warmed up engine.
I was struggling to understand the mounting system for the bucket hooks as well, even after I received them, which was before I got the tractor. It certainly wasn't obvious, at least to me, how they stayed attached to the bucket. However, the bucket hooks are just as advertised, quick-on. I just slid the bracket over the lip of the bucket, and set the tension pin...installed! No drilling or welding, and I can move them anywhere I want along the top of the bucket. I haven't put them under load yet, but they seem to be secure. I have read posts and reviews that say the brackets can work loose, and that sometimes the bracket doesn't fit the bucket, but I had no problem at all installing them.
Yeah, a thumb is probably redundant if you have a grapple.
I've seen some posts here about how the BX25 vibrates at idle, which amuses me because it is way, way smoother than the 2-cyl BX1500.
The most annoying thing about the BX25D so far has been the incessant condensation on the underside of the instrument panel glass, and even on the glass over the fuel gauge. It is stored in an unheated garage, but I still don't get why moisture gets trapped in there and condenses on the glass. It should be roughly the same temperature on both sides of the glass. There is so much moisture that you can't even read the gauges. I've been using work lamps to heat the glass and dry it up, but I would sure like to find a way to prevent it.
The only other issue I had was with the rubber tie rod boots on the front axle. They were severely cracked and dry rotted. I asked the dealer to replace them when he installs the block heater.
   / Required Photos of BX25D #9
The BXpanded bucket hooks fit my BX25D just fine. I have pulled, lifted big stumps with ease using them. They basically just snap on. I think they are great. I only say, check the spring rod occasionally to make sure it didn't over-center and get loose. Great little product that does not alter your bucket! Here are a couple of jobs using the hooks.
   / Required Photos of BX25D #10
I would talk to them about the glass....I think that is a possible issue.
I am dis-liking you guys with those hooks....another thing I have to buy now. :)
2012 Ram 4500 Versalift TEL29N 29ft Bucket Truck (A50323)
2012 Ram 4500...
2012 FORD E-SERIES 11 PASSENGER VAN (A52472)
2012 FORD E-SERIES...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A52748)
2017 KINZE...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
377054 (A51573)
377054 (A51573)
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
