Repower G154 Bolens
/ Repower G154 Bolens #1
bolensg154
Carleton, mi 48117
Bolens G154
Has anyone found an engine that can be swapped with a KE70 with minimal modifications?
For a Bolens/Iseki G154
/ Repower G154 Bolens #2
Ask the member ilikeyourtractor, He has changed engines and He also added a turbo to one.
/ Repower G154 Bolens #3
Welcome aboard.
Rather than clog this forum with numerous spurious questions (I read elsewhere you are thinking of re-boring your engine:
http://www.tractorbynet.com/forums/iseki/384023-bolens-iseki-g154-engine-rebuild.html )
How about you just explain/describe your problem (Won't start, Blown Head Gasket, Dropped a con-rod, Burning oil, etc??) and ask for general advise and options?
One thread topic all to yourself and easy for other people to monitor.
Also, use the "Search" function and you will find the discussion referred to above.
/ Repower G154 Bolens #4
A KE75 should bolt in. It is the motor that is in the G174. They are the same tractor other than the motor. I have a good used KE75 motor.
how much do you want for the KE75?
Where is it located? or how much would shipping be to Carleton, mi 48117?
/ Repower G154 Bolens #6
Dixon Il. Email me for pricing.
UNUSED FUTURE FT-ZDQ160 110V CONCRETE VIBRATOR (A60432)
UNUSED FUTURE...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
(13) WOOD PALLETS (A60432)
(13) WOOD PALLETS...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A60432)
UNUSED SDLANCH...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2014 Freightliner 105' Bucket Truck (A61306)
2014 Freightliner...
