Replacing wear blade on front bucket
   / Replacing wear blade on front bucket #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I am going to replace the wear edge on the front bucket of my loader (7308 NH)
I am currently searching for a used grader blade.
It was suggested to me to just weld it over top of the remains of the original instead of cutting the original off. Any suggestions or comments?
   / Replacing wear blade on front bucket #2
Cut the old one off. It will make life easier. You can also buy cutting edges. They come as flat stock and will be cut to length for you.
Egon
   / Replacing wear blade on front bucket #3
That's likely a good idea but grader blades are really brittle and take a bit of expertease to weld on. When the lip on mine needed replacing I'am pretty sure what was used was ordinary 1/2 by 4 or 5" flat bar champhered down on the leading edge. Welded in easy enough and has lasted quite well.
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
1269 (A50490)
1269 (A50490)
