Replacing wear blade on front bucket
   / Replacing wear blade on front bucket #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I am going to replace the wear edge on the front bucket of my loader (7308 NH)
I am currently searching for a used grader blade.
It was suggested to me to just weld it over top of the remains of the original instead of cutting the original off. Any suggestions or comments?
   / Replacing wear blade on front bucket #2
Cut the old one off. It will make life easier. You can also buy cutting edges. They come as flat stock and will be cut to length for you.
Egon
   / Replacing wear blade on front bucket #3
That's likely a good idea but grader blades are really brittle and take a bit of expertease to weld on. When the lip on mine needed replacing I'am pretty sure what was used was ordinary 1/2 by 4 or 5" flat bar champhered down on the leading edge. Welded in easy enough and has lasted quite well.
Case Ih 2388 Combine (A50514)
Case Ih 2388...
16ft Trailer T/A Equipment Trailer (A50322)
16ft Trailer T/A...
2014 GMC ACADIA SUV (A51222)
2014 GMC ACADIA...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
Zero Turn Mower (A48082)
Zero Turn Mower...
