Replacing wear blade on front bucket
   / Replacing wear blade on front bucket #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
I am going to replace the wear edge on the front bucket of my loader (7308 NH)
I am currently searching for a used grader blade.
It was suggested to me to just weld it over top of the remains of the original instead of cutting the original off. Any suggestions or comments?
   / Replacing wear blade on front bucket #2
Cut the old one off. It will make life easier. You can also buy cutting edges. They come as flat stock and will be cut to length for you.
Egon
   / Replacing wear blade on front bucket #3
That's likely a good idea but grader blades are really brittle and take a bit of expertease to weld on. When the lip on mine needed replacing I'am pretty sure what was used was ordinary 1/2 by 4 or 5" flat bar champhered down on the leading edge. Welded in easy enough and has lasted quite well.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2015 INTERNATIONAL PROSTAR SLEEPER TRUCK (A50854)
2015 INTERNATIONAL...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
