Replacing toplink boot on MF 135.
   / Replacing toplink boot on MF 135. #1
Brakeman
Ontario, Canada
Hey guys was just putting new boots on the Massey and I was wondering about any tips or tricks of replacing the toplink boot. I thought I read a post somewhere but I can't remember where. Thanks
   / Replacing toplink boot on MF 135. #2
Try looking at "The Kid" Refurbushing my Z145 135 Page 19 Post 183 That's the only one I remember. Hope this helps.
   / Replacing toplink boot on MF 135. #3
Greetings Brakeman. When you change out the boot, it's an oportunity to check the draft control spring. I have photos of that processs here on TBN. There are a couple of tough areas to overcome but it can be done with common tools. Here is a link to where I do that.
Draft Control Spring and Boot Repair
Thanks The Kid. That is what I was looking for. I was following your thread pretty solid until things got busy. That is one nice Massey your got yourself. I will have to restart reading your thread, and thanks for all the pictures you have been posting it has helped to put everything into perspective.
I have the MF manuals, but true to life things that people run into helps a bit more.
Again thanks.
   / Replacing toplink boot on MF 135. #5
I'll be honest, what looks to be a 20 minute job can turn into an all dayer sometimes. The retainer nut that holds the spring in will probably be sacrificial at least mine was. I had to take a cold chistle to it to get it loose. The parts are not expensive and I did replace over half the parts. I need to get my front brush guard back on. I'm been pushing down some 1" to 2" saplings and chewing the up. I'm afraid I'm going to bend up the lower guard. Good luck and we are here to help each other to keep from scratching a bald spot on your head. :laughing: -kid
   / Replacing toplink boot on MF 135. #6
Hows the progress on your boot replacement going?
2005 International 4300 Bucket Truck (A52377)
2005 International...
2025 K2215 UNUSED Portable Restroom and Shower (A53117)
2025 K2215 UNUSED...
2007 Mack Granite CT713 Day Cab Truck Tractor (A53117)
2007 Mack Granite...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
WB Mower (A50120)
WB Mower (A50120)
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
