replacing tie-rod boots
   / replacing tie-rod boots #1
GIJOE
Baton Rouge, La.
MAHINDRA 3510 w/ ML112 FEL
I thought this may benefit someone that has a 3510/4110.
The rubber boot on one of the tie-rods seemed to have come out from under the clip that holds it in place while I was pumping grease into it. After removing the tie-rod, clip and boot I noticed the boot was stretched out, and I was not able to get it to stay under the clip. The tie-rod extension boot also showed signs of dry rot, but neither one was busted, so I knew there wasn't any contamination in either joint. Not wanting to spend approximately $600 to replace both tie-rods and extensions, the guy at my local NAPA found replacement boots that fit. I had to buy two sets of ball joints to get the boots I needed, but $80 was way cheaper. The tie-rod uses a boot from an upper ball joint that fits a 2000 Toyota 4runner (104279), that came from NAPA, and the extension uses a boot from a lower ball joint that fits a 2003 Honda Accord (K80228), that came from O'Reilly's. The repair was easy and straight forward. Here are a few pics.
   / replacing tie-rod boots #2
Awesome! you just added my first stock parts from yota and Honda lol
   / replacing tie-rod boots #3
Rubber boots like this for tie rod ends, ball joints and such are fairly common generic parts that you can find at most autoparts stores for maybe a couple of bucks each if you look around.
Ball Joint Boot at AutoZone.com - Best Ball Joint Boot Products for Cars, Trucks & SUVs
   / replacing tie-rod boots #4
2014 Honda Accord Sedan (A50324)
2014 Honda Accord...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 Land Rover Range Rover Supercharged 4WD SUV (A50324)
2018 Land Rover...
1265 (A50490)
1265 (A50490)
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
