Replacing the ignition switch?
/ Replacing the ignition switch? #1
blackd
Platinum Member
So MD
Yanmar FX24D replaced with Massey GC2400
Does anyone have experience/directions for replacing GC2400 ignition switch?
/ Replacing the ignition switch? #2
I had to pull mine back in 2021 (needed cleaning badly) but don't remember much about it. would think if was hard something would have stuck in my mind.
Do you remember how to dismantle the new switch to install
/ Replacing the ignition switch? #4
no don't remember anything really.just that I had to blow it all out with shop air due to crud.
An update: These ~82YO eyes and brain finally happened into a realization that this ignition switch is identical to all others they have encountered. This is a well designed/pretty unit with the black on black retaining ring nearly impossible to detect (remember the ~82YO eyes and brain), but it screws off just like most other switches. It is an easy fix.
So God willing, and with warmer weather, I will complete this job. Just not today.
/ Replacing the ignition switch? #6
thought it was setup like that just was not able to verify. eyes only 57 but getting cataracts removed soon. looked real quick at my gc2400 and was also not able to easily see ring this time. thanks for the update.
Some progress! I replaced (but did not fully install) the new ignition switch. I'll do that in the next couple of days.
The procedure to remove is:
1. Remove the foot screen to gain access to the back of the switch.
2. Remove the ignition switch trim ring.
3. Push the ignition switch back and pull down on the wiring harness. Space is limited to do this so it takes some effort.
4. Pull back the wiring harness shield and depress the shield lock to remove the connector.
5. Connect new switch to connector and start tractor to check if everything works. Voila!!!
It's done, and parked in the normal spot. I need some new screws/bolts to better attach the foot screen.
/ Replacing the ignition switch? #9
My screen messed up on lower right tab, washers involved to hold it and it still slips. and then gets in the way when removing the FEL connections. not a huge fan of that design.
Aluminum Bell (A65583)
AUCTION STARTS HERE @ 9AM (A64278)
AUCTION STARTS...
Farmhand CG 3000 Tub Grinder / Bale Processor (A66408)
Farmhand CG 3000...
Beverage Truck Body (A64556)
Beverage Truck...
2023 Schulte FX-318 Flex-wing Rotary Mower (A66285)
2023 Schulte...
Copper Eagle Weathervane (A65583)
Copper Eagle...
