Replacing teeth on a Harley take
   / Replacing teeth on a Harley take #1
KeithT
West Virginia
Kioti CK3510HST SE
Hello,
I am buying a used Harley take that is missing 5 teeth. I looked on you tube and no information on replacing broken teeth. Anyone have any experience with this? Is it possible? Thank you
   / Replacing teeth on a Harley take #2
I think the teeth are threaded into the drum might try heat and vice grips, Found some that are weld on also..
   / Replacing teeth on a Harley take #3
   / Replacing teeth on a Harley take #4
Each brand is probably somewhat different. I have a ventrac power rake which is essentially the same thing. The carbide tips have spring steel that hods it in with a separate steel collar on the outside to fill in the overhang of the hole. It allows enough play in the tip to be able to get a chisel into it to pop it out if need be.
   / Replacing teeth on a Harley take #5
Electric Mobility Scooter (A51694)
Electric Mobility...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2006 International A325C 6.0LV8 Turbo Diesel Engine and Transmission (A50325)
2006 International...
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
