Replacing teeth on a Harley take
/ Replacing teeth on a Harley take #1
KeithT
West Virginia
Kioti CK3510HST SE
Hello,
I am buying a used Harley take that is missing 5 teeth. I looked on you tube and no information on replacing broken teeth. Anyone have any experience with this? Is it possible? Thank you
/ Replacing teeth on a Harley take #2
I think the teeth are threaded into the drum might try heat and vice grips, Found some that are weld on also..
/ Replacing teeth on a Harley take #3
/ Replacing teeth on a Harley take #4
Each brand is probably somewhat different. I have a ventrac power rake which is essentially the same thing. The carbide tips have spring steel that hods it in with a separate steel collar on the outside to fill in the overhang of the hole. It allows enough play in the tip to be able to get a chisel into it to pop it out if need be.
/ Replacing teeth on a Harley take #5
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59909)
2007 TRAILMOBILE...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
6055 (A61165)
6055 (A61165)
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2025 Grapple Hydraulic Mini Skid Steer Attachment (A61567)
2025 Grapple...
UNUSED RAYTREE RMVR76 - 76" VIBRATORY ROLLER (A62131)
UNUSED RAYTREE...
