Replacing seized mower blades
/ Replacing seized mower blades #1
Clinite
Kubota B2910
A stitch in time saves nine. First I am no expert. My problem was a Woods BB 60 mower that was neglected and needed blades attended too. I searched the Web for advice. I appreciate the shared knowledge , but was looking for more specifics. Here is my contribution to the knowledge base from my quest.
First, Blaster or the equivalent is a great product. The nut was soaked over night.
The most helpful advice is to secure the blade to negate the spin when using breaker bar to remove bolt. I found placing two 2x4 cut to length to wedge the support bar
Heat the nut, a good 15 min
Maximize torque
Apply more Blaster and clean build up around pin. Used hand sledge and appropriate rod to remove pin
Voila
/ Replacing seized mower blades #2
Consider in the future investing in a torque multiplier wrench. Was what all heavy equipment and truck tire people used for decades.
Torque Multiplier Lug Wrench, 1:78 Ratio, Heavy-Duty at EZLugWrench.com - YouTube
They easily generate over 1,000 lb-ft of torque.
When looking for one pay attention to their internal gear ratio. The higher the ratio the more power.
Here is one example from Amazon.
US PRO Tools HGV Truck Torque Multiplier 1" Drive Wheel Nut Wrench +Sockets 6911 | eBay
Dave M7040
/ Replacing seized mower blades #3
Ummm... I could have used that last year for a neighbor's mower blade that we couldn't get off with 450 ft/lb air tools (average homeowner variety). We ended up just replacing the whole spindle. Tried heat, pbBlaster, bars, etc. All to no avail.
Looks like a good tool to have around.
Thanks. On my Christmas list.
/ Replacing seized mower blades #5
I picked up a a 4:1 torque multiplier for $10 at local flea market... Similar to one below... Good to 1000 ft-lbs with max of 250 ft-lbs input...
Also be sure when tightening nut you meet torque specs, think someplace I read some go as much as 350 (+/-) ft-lbs...
Dale
2012 FRAC TANK 500BBL WHEELED (A65643)
2012 FRAC TANK...
60 Traffic Cones (A65579)
60 Traffic Cones...
Wacker PT3 Water Pump (A65640)
Wacker PT3 Water...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2023 JOHN DEERE 333G SKID STEER (A64277)
2023 JOHN DEERE...
