Replacing seal in the bottom of a bushhog cutter
   / Replacing seal in the bottom of a bushhog cutter #31
My reason for filling my gearbox with corn head grease ($20 total, including shipping and an extra tube of grease) is that I'm not sure how to or if I would be able to get the old seal off; by all descriptions, including yours, it's a real bear even when you know how. If I knew I could get it off, I would have replaced it. And just to assure you, I'm not offended at all. Just pointing out why I personally went the corn head grease route and got-R-done. :thumbsup:
It may not be that hard to get off.
I was expecting the worst on my 20 year old 4 ft slasher when I had to replace the seal and was pleasantly surprised how easy it all came apart with a bit of leverage .
   / Replacing seal in the bottom of a bushhog cutter #32
For those concerned with using grease in the gear box, King Kutter now ships implements with "000" grease in theirs. It's looks like cold honey.
   / Replacing seal in the bottom of a bushhog cutter #33
Another good NLGI 0 grease to use in the gearbox is Lubriplate 5555. I buy a 5 gallon pail about every 10 years and use a pail hand pump to fill the gearbox. I discovered it because it was specified by International for bottom rollers on my TD340A, and it doesn't leak out so fast wehn the seals are bad. Prices vary from about $110 to $160 for 5 gallons. Has the same properties described above in this thread.
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
