Replacing Oil Pressure Indicator
/ Replacing Oil Pressure Indicator #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
My M7030 has idiot lights for oil pressure indicator. It doesn't work. I have found the end of the wire and the orifice where it is attached to the tractor. I am presuming it is just a pressure switch. Is there a way i can connect a regular oil pressure gauge to that orifice?
/ Replacing Oil Pressure Indicator #2
You probably have a simple pressure switch screwed into a threaded hole in the block. You should be able to replace it with either a sending unit or a fitting and run either a wire or a thin oil line to the dash where you may install the appropriate gauge. Was that the question?
Yes sir, that answers my question. Thank you.
Now.... has anybody done it?
/ Replacing Oil Pressure Indicator #4
I did it on a Massey Ferguson I had a few years ago. Even made a hole in the instrument panel with a hole saw for the gauge. Mine was hooked up via a very small oil line (maybe 1/8"). That would be the weak link, however, because if the oil line were ever compromised you'd lose a serious amount of oil in a short time.
/ Replacing Oil Pressure Indicator #5
On this type of conversion I've sometimes kept both the pressure gauge and the light. Just install a "T" in the block and you can run both. A light gets attention faster than a gauge but I like the gauge because it give more information.
Remove the sender for the light and make sure you get fittings for the block with the right thread. Most are 1/8" pipe but I've seen metric too.
Just about any sender that grounds at low oil presure will work. The idiot light sender doesn't need to be from Kubota. Most are set to turn the light on at 5-7 lbs.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
2008 Toro Multi Pro 1200 Turf Sprayer (A61572)
2008 Toro Multi...
John Deere 5090GN (A60462)
John Deere 5090GN...
