Replacing MX5 rotary cutter blades
/ Replacing MX5 rotary cutter blades #1
sros990
West Virginia
JD 990
I need to replace the blades on my JD MX5 rotary cutter. The manual indicates that the blade hardware torque is 728 lb-ft and that I should use a torque multiplier to remove the blade. I don’t own a torque multiplier and don’t want to spend around $300-500 to purchase one.
Can I use a 1/2 socket wrench or other tool to get the blade off and back on?
Thanks,
Steve
/ Replacing MX5 rotary cutter blades #2
I just did the blades on my Rhino cutter. They torque to (only) 350 lb/ft. '
I tried using my 1/2" breaker bar with an adaptor to a 3/4" socket (couldn't find a large enough socket in 1/2" size). I used a nice long cheater bar and promptly broke my breaker bar. It was a Craftsman, so I have a new one now... :)
I was able to get the nuts off with a (nice new) 3/4" breaker bar. Long cheater bar, again, this time nothing broken.
To put the nuts back on I tightened them as far down as I could, but I'm having an issue with one of the blades (I have another post about it, but no replies :().
/ Replacing MX5 rotary cutter blades #3
I find an impact wrench to be very handy if not mandatory.
/ Replacing MX5 rotary cutter blades #4
I use a 3/4" drive with a 4' cheater bar to loosen/tighten the blade bolts on mine. I did not have a 1/2" socket big enough to fit the bolt anyway so ended up purchasing a 3/4" drive set
I think the torque specs on mine are only 450ft/lb so you may need to get a longer cheater bar :)
/ Replacing MX5 rotary cutter blades #5
I just put a 6' piece of pipe over my 3/4" bar affixed to the 1 1/2" socket on the nut, but my LX4 bolts are only torqued to 450 ft lb. At your 728 ft lb torque, you'll have to push harder than I did or use a longer piece of pipe. At 450 ft lb, it was easy, only about 75-80# on the end of the 6' pipe. Have taken the bolts off and back on twice now, once/yr.
I used a couple of quick clamps to clamp a nut and stump jumper back in place to put each bolt in place. Your MX5 is probably similar. Be sure and prop up your cutter; don't rely on your 3ph to keep it in place.
Ralph
832732 (A61166)
832732 (A61166)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
832755 (A61166)
832755 (A61166)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2013 BMW 750i Sedan (A61569)
2013 BMW 750i...
