Replacing hydraulic hose
/ Replacing hydraulic hose #1
NoTrespassing
Elite Member
East Central Illinois
Kubota 1999 L3710 HST FWA
Hey all, I developed a leak in the hydraulic hose going from the tractor to the loader yesterday on my l3710 Kubota. I probably lost a quart of fluid. I managed to get the loader off the tractor and finished snow plowing. I got a replacement hose made and bought some fluid. Quite a bit of fluid drained out of the loader after I took the hose off.
I need advice replacing the hose and bleeding off the air.
Kevin
Kevin
Or maybe I shouldn't be worried about air in the lines?
/ Replacing hydraulic hose #3
Replace the hose and keep cycling it and you will get the air out. In the worst of cases you might get an airlock and have to crack a fitting loose but that is a rarity.
/ Replacing hydraulic hose #4
I've never seen a specific method of bleeding air out of an open hydraulic system like Kubota uses, or of needing to do so.
After you cycle the loader up and down a few times I doubt you will notice any air.
/ Replacing hydraulic hose #5
Once you're done cycling the loader a few times, shut down and check the fluid level. Since the tranmission holds some number of gallons (10 on my Branson), a quart or two is not going to change the level too much.
/ Replacing hydraulic hose #7
Buy some caps for the hoses male and female for when you do have to replace them. All I do is ease into it with the lever the first cycle or two an like others just run the thing recheck the fluid.
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
1970 Freehauf Lowboy, 20' Deck with 3' Dovetail (A62679)
1970 Freehauf...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
Stout Buckets HD78-3 Rock Bucket Skid Steer Grapple (A65640)
Stout Buckets...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
