replacing hydraulic hose
   / replacing hydraulic hose #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Hi
Anyone have a good way to get to the fiting to remove and replace the hose feeding hydraulic oil to the backhoe? I see no way to get to the fitting unless I remove the loader control valve. the engineer's have out done themself's again.
Charlie.
   / replacing hydraulic hose #2
Hi
Charlie.
How about using offset wrenches? I had to do that with my backhoe. Also needed to remove a couple of other lines in order to access the one I needed to change as I recall.
Thanks for the reply I did try the offset wrench, just no room to work. by the way I forgot the tractor is a ford model 1920 built in 1995. If they had made the port on the valve body extended about 1 inch it would have made replacing the hose a 15 minute job.
Charlie.
I need an easy button
   / replacing hydraulic hose #4
Hi
Charlie.
Looks like you need a set of hydraulic wrenches. Hydraulic wrenches are offset and thinner for those hard to reach spots.
   / replacing hydraulic hose #5
Or maybe a Crow Foot Wrench. Use them with an extension on your socket ratchet drive. [ame]http://www.amazon.com/TEKTON-2575-8-Inch-Crowfoot-10-Piece/dp/B000NPUJNA/ref=pd_bxgy_hi_text_b[/ame]
Hi
I tried all those tools, just no room. but while i was finishing breakfast my wife was able to get a wrench on the nut enough to break it free, I was then able to turn the hose and back it out. Had a new hose made and bought an adaptor to screw into the valve body with a swivel nut I could screw the hose into. used a deep socket to screw the adaptor into the valve body atached the hose to the fitting which is now about 1.0 2.0 inches below the valve body where I can use 2 wrenches to tighten.
Thats my story and I'm sticking to it. I thing I will have to start letting my wife help me more often.
Charlie.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51247)
KNOW BEFORE YOU...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
