replacing engine oil filter every change
   / replacing engine oil filter every change #1
big bubba
Elite Member
arkansas
M8540
ok, have 3 vehicles all with different applications. they're high mileage (combined 700k miles on the 3)
5k change intervals w/full syn oil, oem filters. always change filter when i do changes. given that all the engines are in good shape, do i need to change the oem filter every time, or every other change given that they consume very little oil between changes?
i ask a lot of my vehicles, & maintain accordingly. your thoughts, thx in advance.
well i agree with the above, maybe why the engines are doing well.
i just got to thinking though since some recomm 10k oil changes w/full syn (which i'll never do), that maybe it would apply to filters, esp if the change is 5k intervals.
just wanted to hear opinions, regards
   / replacing engine oil filter every change #5
Why would you dump a quart of dirty oil, into a reservoir of new, clean oil by not changing the filter? You would essentially contaminate the new oil instantly.
IMO, you should ALWAYS change the oil filter when doing the oil change.
I also think that waiting until 5k miles to do oil changes is far too long, unless the miles are all interstate miles. I do mine every 2500 miles. I've done that ever since I was 16 years old, and I've NEVER had an engine problem. (now in my 70's)
duffer: followed your change interval schedule with dyno oil for many years. when changing to full syn (castrol) i bumped it to 5k intervals w/oem filter.
just curious to see if i really need to change oil filter every time as well always using the same oil type, etc. regards
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2017 FREIGHTLINER...
Zero Turn Mower (A59231)
Zero Turn Mower...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
