Proper oil for Tractor
/ Proper oil for Tractor #1
smfcpacfp
Veteran Member
Sands Township, Marquette Co, Michigan
Kubota B3030HSDC
I generally use Mobil 1 in my cars and I want to do so with my tractor. In my B3030 owner's manual it says, When an off-road vehicle engine runs on a high sulfur fuel, it is advisable to employ the CF, CD, or CE lubricating oil with a high total base number. In a chart it says CF is recommended with a remark TBN (I assume total base number) > or = 10.
I went to the API website and all of the API oils specified in the Kubota manual are now obsolete! There are only 3 API diesel service categories that are current: CH-4, CI-4 and CJ-4.
However none of these oils are specified for high sulfur diesel.
It does say for the CJ-4 specification that if you are using it with high sulfur oil, consult the manufacturer for the oil change interval. Maybe I should just start buying the on road diesel and take the tax credit for off road use.
Here is a link to the API service categories:
http://www.api.org/certifications/engineoil/pubs/upload/EngineOilGuide_March2010.pdf
Any thought as to what I should be using in my tractor?
/ Proper oil for Tractor #2
Sulfur is bad stuff. In the oil patch, H2SO4 in natural gas will eat holes in ordinary steel pipe, and they have to use stainless steel when it is present. My preference is to use ultra low sulfur fuel at the highway vehicle pumps.
/ Proper oil for Tractor #3
Todays low sulfur diesel fuels do not require a high total base number(TBN) anymore so ANY good brand oil like Delvac,Delo,Rotella of currant HDEO API(CJ4) will work just fine.
and Sulfur is a good thing, that's part of what lubricates your injector pump/injectors. Thats why older tractors should run a additive for lubricity because todays fuel is dry,lacks sul.
/ Proper oil for Tractor #4
I use Mobil 1 0w30 synthetic in my 4010 engine because it is what I was using in every other engine I own, including our old 1983 240D for a couple years or so before selling it. Now, my new VW TDI requires Mobil 1 ESP or Castrol SLX to meet their VW 507 spec. The ESP is only available at Pep Boys so far, and in 5w30.
The 0w30 is rated "gasoline" but has a light diesel rating. The 5w40 "SUV" oil is fully diesel rated if you want to go long hours on an oil. I change once/year, generally about 50-60 hours any more.
Ralph
/ Proper oil for Tractor #5
the problem with those mobil oils listed is the low zddp and calcium levels, they may be rated for light duty diesel. But any of the true HDEO is going to be more shear stable as well as have a better add pack for heavy diesel use..........
/ Proper oil for Tractor #6
Here is some VOA's virgin oil analysis;
Default Re: Synthetic Engine Oil
M1 TDT 5W-40, M1 0w-30,
ELEMENTS
IN PARTS PER MILLION
ALUMINUM 2 0
CHROMIUM 0 0
IRON 10 1
COPPER 2 0
LEAD 0 0
TIN 1 0
MOLYBDENUM 3 0
NICKEL 1 0
MANGANESE 1 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 0
BORON 30 0
SILICON 2 5
SODIUM 9 2
CALCIUM 1217 3204
MAGNESIUM 765 9
PHOSPHORUS 854 1249
ZINC 992 1403
BARIUM 0 0
PROPERTIES
SUS Viscosity @ 210ーF 64.2 75.4
cSt Viscosity @ 100ーC 11.39 11.55
Flashpoint in ーF 370 425
Fuel %
Antifreeze % ? 0.0
Water % 0.0
Insolubles % 0.2
TBN 4.5 12.5
1st column is the mobil 1 TDT 5w-40, Second column is Rotella HDEO 5w-40 T-6 Still looking for my voa of mobil 1 0w-30.
The mobil 1 0w-30 is a great oil I use it in some of my Gasoline engines, but the tdt formula is more robust and any hdeo is yet again more robust than the tdt
/ Proper oil for Tractor #7
Here is a grouping of four popular HDEO's;
VOA
ALUMINUM: ........1...0...0...0...
CHROMIUM: .......0...0...0...0...
IRON: 1..............2...1...1...0...
COPPER:........... 0...0...0...0...
LEAD: ...............0...0...0...0...
TIN: ................0...0...0...0...
MOLY: ..............0...3...0...69...
NICKEL:........... 0...0...0...0...
MANGANESE: .....0...0...0...0...
SILVER: ...........0...0...0...0...
TITANIUM: ........0...0...0...0...
POTASSIUM: .....0...0...0...3...
BORON: ...........154...321...0...371...
SILICON: ..........6...5...4...5...
SODIUM: ..........1...1...0...1...
CALCIUM: ......2107...2909...4038...1121...
MAGNESIUM: ........421...258...7...320...
PHOSPHOROUS: 1090...1138...1252...893...
ZINC: ..............1216...1388...1346...1097...
BARIUM: ............0...
SUS VISC. @210F: 78.6...80.7...n/a...80.7...
Cst Visc. @100C: 15.02...n/a...11.55...15.7...
Flashpoint: 425...420...425...nla...425
Fuel %: 陂*
Antifreeze %: 陂*
Water %:0.0
Insolubles %:0.0
TBN:............ 8.9...9.6...12.1...14...9...
TAN:
ISO Code:
1st column delvac 1 5w-40, second column motorcraft 15w-40, third column is amsoil hdd 5w-30, fourth column is chevron delo 400 15w-40.
as you can see here the amsoil hdd (heavy duty diesel) is a winner and at a low weight 5w-30 its a real performer, the bargain here is the motorcraft 15w-40 which is a great deal of performance for such a cheap purchase price
Thanks for the information guys.
I bought enough Mobil Delvac 1 5W-40 to do the job. I live in the super boonies but there is a truck repair facility 5 miles form and they carry Delvac in bulk, so I had to bring my own container.
/ Proper oil for Tractor #9
You made a great choice. You won't go wrong on that. I assume you are a change annually kind of guy, so you will be fine!!!! Filter?
/ Proper oil for Tractor #10
We have a FT404, that takes: STOU 10W/30 GL-4 (equiv. SAE80W transmission oil):
  • Engine sump 7 l (API CD)
  • Gearbox 27 l (MF1135, M2C 86A, JD J20A)
  • Front axle 7 l (MF1135, M2C 86A, JD J20A)
  • Lifter 12 l (UTTO for hydraulics)
  • Steering 0.8 l (UTTO for hydraulics)
I would recommend what our dealer already has put into the tractor, Agrol Turbo Kombi, a STOU oil. Similarly we can use Statoil MultiWay or OKQ8 T1000, all 10W-30. We can also use Biltema Tractor Oil Universal, Kombiolja 10W-30 at 269 SEK for 10 liter.
In the FOTON user's manual, the requirement for oil is separated for the engine and for the transmission/hydraulics. These STOU oil recommendations above exceeds the requirements for the tractor. Both the low cost and the handling of a single oil bought in large quantities (10 or 20 liter) makes STOU a given for these 1980-decade of tractor technology.
That's what we practise with our Foton FT404, and it also came with Agrol Turbo Kombi oil in all reservoars. It worked well during the Nordic cold winter period as well.
We have also found Baldwin equivalents for the fuel & lube filters:
  • Clarcor Filtration: WBF7608 -> Baldwin BF7608
  • Clarcor Filtration: WB202C -> Baldwin B7451
/ Proper oil for Tractor #11
Kubota's oil suggestions are GOOD, if and only if, you are using #2D or LSD type fuels.
Sulfur is corrosive and causes the oil to acidify over time, with the current (since Oct 2006) ULSD (Ultra Low Sulfur Diesel) there is no need to use the "older" API oils, in fact doing so with ULSD is not a good thing in the long term. The "newer" CJ oils are specially formulated for ULSD but are not appropriate for engines using #2D or LSD fuels, although for our applications where oil is changed on a relatively early schedule, I doubt there would be any problems using it.
Modern oils are FAR FAR superior to those that were used even in the late '80s, I suggest we all use the most current oils we can find, unless there is a good reason to use an oil with a previous API designation (like you are using LSD fuels).
/ Proper oil for Tractor #12
I live at 7,100 ft. elev. but summers get in the high 80's sometimes and winters in the -20 range. I use Amsoil HDD (heavy Duty Diesel) 5W30.
DEWFPO
/ Proper oil for Tractor #13
The Amsoil HDD is great oil I have used it before it is a great oil, Especially with your listed temperatures I am at 6300 feet here, but we get 20 below on average jan and feb and as low as 30 below......so I hi fellow cold weather friend
/ Proper oil for Tractor #14
:drink:
DEWFPO
/ Proper oil for Tractor #15
Yea their HDD is good but a 15w-40 is too thick for me..There new 5w-40 looks better.
/ Proper oil for Tractor #16
1*Maybe I should just start buying the on road diesel and take the tax credit for off road use.
2*However none of these oils are specified for high sulfur diesel.
1*You would not be gaining a thing.
On road and off road are the same thing .
2*Shouldn't matter much if any as nearly all the high sulfur diesel has been used up
And all they make now is U L S D .
/ Proper oil for Tractor #18
the hdd is 5w-30
overpriced..Use there 5w-40 since at least it passes the CJ spec. There new 5w-40 has a better HTHS, pump temps are close, 4-ball is meaning less so throw that out the door but there HDD has a better TBN. If you need it use that..For the extra $6 per gallon, you might not need it. The TBN is lower on CJ oil since it has less ZDDP in it.
I used it for a few years (hdd=S3000) but not needed.
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
100 GALLON L SHAPE FUEL TANK (A62131)
100 GALLON L SHAPE...
NEW HOLLAND 351 GRINDER/MIXER (A62130)
NEW HOLLAND 351...
2019 RoGator RG1300C Spreader (A63109)
2019 RoGator...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
