Replacing CK20S light switch ?
   / Replacing CK20S light switch ? #1
Slackdaddy
Land of the Free
Kioti CK20HST
My 2005 CK20S headlights, tail lights don't work, only the right turn signal works. Both rear flashers do work.
I am guessing the Light Sw is bad?
How do you remove/replace this switch, did a forum search and not finding it.
Thanks,
Nick
   / Replacing CK20S light switch ? #2
My CK20 is older than yours, but based on what I have seen on it you will need to remove the dash or at least the cover plate below the dash. Michigan Iron may have an exploded view of the dash in it's parts catalog that might help.
Cheers
Rancho
   / Replacing CK20S light switch ? #3
From memory the wiring goes underneath to the rear. Just check your connectors before pulling the switch out.
   / Replacing CK20S light switch ? #4
I would suspect fuse or corroded or broken wire before switch. I sure wouldn't order one before diagnosing the problem first. The chances of it being the switch are very low.
2009 Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
2009 Grady-White...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
6-CNH Rear Tractor Weights (A50774)
6-CNH Rear Tractor...
2008 Ford Taurus X SUV (A50324)
2008 Ford Taurus X...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
