Replacing a Section of Steel Tube
   / Replacing a Section of Steel Tube #1
docscott
Landrum, SC
Ford 1320
I have a hydraulic leak in a rigid steel tube that goes between my hydraulic pump and my transmission on a Ford 1320 tractor. The tube has a banjo fitting on either end. The front half of the tube is in good shape, but the back half is quite rusty. Is there a type of connection that I could use if I cut away the back half of the tube and connect a rubber hydraulic hose with a banjo fitting to replace the damaged section? Preferably a repair that could be done without removing the tube from the tractor as the front connection will require quite a bit of disassembly of the tractor.
Thanks, Scott
   / Replacing a Section of Steel Tube #2
Do a search (here and Google) for "swagelok" fittings. You will have to be able to accurately measure the tubing size.
   / Replacing a Section of Steel Tube #3
you could get compression hyd fittings to get to rubber.. or weld/braze on fittings to do the same...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2018 FORD EXPEDITION (A51406)
2018 FORD...
UNUSED AGT AIR COMPRESSOR W/ 420CC MOTOR (A51248)
UNUSED AGT AIR...
2019 FREIGHTLINER M2 26' BOX TRUCK (A51247)
2019 FREIGHTLINER...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
