Replacing a Section of Steel Tube
   / Replacing a Section of Steel Tube #1
docscott
Landrum, SC
Ford 1320
I have a hydraulic leak in a rigid steel tube that goes between my hydraulic pump and my transmission on a Ford 1320 tractor. The tube has a banjo fitting on either end. The front half of the tube is in good shape, but the back half is quite rusty. Is there a type of connection that I could use if I cut away the back half of the tube and connect a rubber hydraulic hose with a banjo fitting to replace the damaged section? Preferably a repair that could be done without removing the tube from the tractor as the front connection will require quite a bit of disassembly of the tractor.
Thanks, Scott
   / Replacing a Section of Steel Tube #2
Do a search (here and Google) for "swagelok" fittings. You will have to be able to accurately measure the tubing size.
   / Replacing a Section of Steel Tube #3
you could get compression hyd fittings to get to rubber.. or weld/braze on fittings to do the same...
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
UNUSED RAYTREE RMBG72-72" ROOT GRAPPLE (A51248)
UNUSED RAYTREE...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
UNUSED AGT ATK-B1000 2 POST CAR LIFT (A51248)
UNUSED AGT...
2023 UNVERFERTH 632 LOT IDENTIFIER 146 (A53084)
2023 UNVERFERTH...
