replacing 3000 axle seals
   / replacing 3000 axle seals #1
crewguy
I am trying to figure this deal out. I need to replace all four seals in my rear axle. If my axles have the nut (instead of the collar) and I get the nut off- do I still have to use a puller and remove the bearings to get to the seals? I understand there is also a seal located right inside the housing, but I want to replace all four seals. I have new brake shoes and want to do the job right the first time. Ford/New Holland quoted $250 (nut-type) or $350 (collar). Those prices are labor-only.
   / replacing 3000 axle seals #2
The outer bearings are a semi-press fit to the axle and will have to be pulled from the shaft after the nut/shrink collar is removed The few I have done that way were a tough pull. I do most of the seal replacement jobs that come to my dealership. If your tractor has a differential lock, it will have nuts retaining the bearings. If it is less difflock, it will have collars. From a total cost standpoint, it is quicker and (almost) cheaper for me to torch out the collar(if equipped) and bearing rather than use the OEM puller. I can completely disassemble one axle of either style in less than a half hour. Cleanup of parts and reassembly will take longer than that. And you end up with new bearings instead of old ones that have been severely loaded by a puller. One needs to be pretty fair with a cutting torch to not damage the threads on the style using nuts. Heating the bearings prior to reassembly helps tremendously. Your labor quote isn't far off: I'd probably be on the lower end of the range, but you would be buying the bearings which you may not be planning on currently.
Edit: My half hour disassembly time is for an axle/hub removed from the tractor and delivered to the shop.
I am in the process of pulling the axles. I plan to take them to the dealer. This tractor doesn't have the posi-lock. How much will the bearings run me?
   / replacing 3000 axle seals #4
Looks like about $50 per side for outer bearing cups & cones. That's for a 3000 less differential lock.
We pulled the axles and they have the nut. That will save me a C-note.
Do I reuse the same shims per side when I replace axle bearings? New bearings don't change clearance numbers?
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
AEREATOR (A58214)
AEREATOR (A58214)
Deere 310SK (A57148)
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
