Replacing 1949 spark plug wiring, front mounted distributor
/ Replacing 1949 spark plug wiring, front mounted distributor #1
cfb
Bronze Member
Cleveland, Ohio
1949 Ford 8N, Ingersoll 448, Ford 16HP Diesel
Hello,
In getting ready to prime the oil pump through that plug on front of engine (it is 15/16), I changed the oil, new oil filter, and new oil in the air filter container. I cleaned the plugs - oh separate question on them. I heard autolight 437 is what I should use, but auto dealer said autolite 216 is the replacement, but I recently read that the Autolite 216 is for later models than mine - so do I look harder for A437s?
I put a tablespoon of transmission fluid down each cylinder since its been sitting for a year. I charged the battery, and just cranked it a brief moment to get that oil moving. With the plugs out, I felt the compression on two of the holes and it felt really strong, so hope that is a good sign. But somehow in the process, I saw the #4 plug became pulled out of the boot at the distributor -leading me to this question. The wire pulled right off the copper end inside the boot. Instead of wire, what I expected to see, it was like felt strands, like a rope. I never did this so did not know what to expect. I read where I should replace with copper core wires. The Ford dealer said using copper is old school. He has a set for $44 but I would have to cut them to size. For same price he has a custom fit set, but I think he said carbon fiber. He said that is what's being used now. I'd appreciate your thoughts please.
Also, the wires run through a conduit atop the engine which has four slots, but the boot is fatter than the slot, so I thought maybe I should go with the version I have to cut - but the dealer said he can show be how to put it through - do you just squeeze them through?
Finally, my numbering, as you probably know, from bottom left and clockwise on the distributor, is 1,2, 3 4. It seems that they matched to the plug with number 1 being at front of engine followed by 2,3 4, with 4 being last toward the steering wheel. Is this the right order? As I read in the manual that the firing order is 1,2,4,3. So does the positioning or matching to the plugs matter to the firing order?
Wow, sorry for the length, but I appreciate all your help. cfb
opps. sorry, at the distributor, the numbering is actually this. on the left side 1 is on top and 2 at bottom. On the right side (as looking from the front of the tractor) it is 3 on top and 4 at bottom. thanks. cfb
Unload Auger Tube for John Deere Combine (A65640)
Unload Auger Tube...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
3Pt Hydraulic Post Driver (A66408)
3Pt Hydraulic Post...
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
Rol-Air gas powered portable air compressor, Coal Valley, IL (A65640)
Rol-Air gas...
Hedge Posts (A65640)
