Replacement Wheels for B1750
/ Replacement Wheels for B1750 #1
AndyF
Central NY
Kubota B8200 & B7200
My new to me B1750 has filled rear tires and I am seeing some corrosion at the valve stems. The wheels/tires are turf tires and I would prefer R4 or Ag for the work I will be doing with the tractor. Where can I find reasonable prices for replacement wheels?
/ Replacement Wheels for B1750 #2
Are these tubeless, and it's leaking around the stems, or is the tube leaking and it's coming out around the valve stem? Do R4's or ags require a different size rim? If you get the old tires off, maybe brush the rims, and if they are not pitted/corroded too bad, I would just weld up the old valve stem hole, and drill another in a different spot. Lot cheaper that a replacement wheel.
I'm looking at replacing the wheels and tires. The ag & R4's will not fit on turf rims. Your suggested repair is what I'm considering doing before selling the Turf tires and wheels.
I guess the question more generally is whether the wheels, especially the rears are unique to Kubota or can I look to other suppliers also?
/ Replacement Wheels for B1750 #5
Most dealers have extra inventory left from most models sold and many might fit your tractor. Sometimes just asking might get you good results! We often have to use e-bay or other sources to sell them.
Art,
Thanks for the suggestion. I've asked your Canastota parts department through an emailed inquiry. Hopefully good news. My local dealer's price is in the low 4 figures for a set of wheels and tires.
6' Bush Hog (A62613)
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
SANY SY35U EXCAVATOR (A63276)
SANY SY35U...
Cultamulcher (A66408)
2004 GMC 5500, Duramax Diesel Truck Vin# 1GDE5E1234F520387 (A62679)
2004 GMC 5500...
X-Star 300 Gal Fuel Tank (A64127)
X-Star 300 Gal...
