Replacement lower lift arms.
   / Replacement lower lift arms. #1
MudMixer
Mahindra 2538
Does anyone know of a cheaper replacement for the lower lift arms of the 3 point hitch on a 2538 other than the Mahindra factory parts? The Mahindra parts cost over $300 just for one lift arm!
You are probably wondering why I need the arms replaced. I bought the tractor used with about 250 hours on it. Most of the tractor is in great shape but the previous owner used it for snow removal/salting. I removed the back hoe to find the bearings in the lower arms completely rusted and seized up. I tried just a out everything to get them to break free.
   / Replacement lower lift arms. #2
I would work at them with whatever different penetrants etc to free them up, including a torch if you can safely use it in the area. If they are totally useless you might get a PRO welder to cut off the old swivel eyes and weld new ones on - the weldable ends aren't very expensive just be sure to have a competent welder do the welding if you can't.
   / Replacement lower lift arms. #3
Do you think you can install one of these at a cost of around 170.00 from Agri Supply. Could be a better option than replacing or rebuilding the arms.
Pat's 3-Point Quick Change Hitch - Category 1 With Stabilizer Bar
   / Replacement lower lift arms. #4
A friend brought a pair of lower lift arms to me for help. All four of the swivel eyes were rusted up and would not move. I put a large bar - 1 1/8" diameter - in my vice and slipped on one eye. Continuous pulling/pushing - WD40 - torch heat. Once we got it broken free and moving - it was just a matter of time and continued pushing/pulling. It took around four hours and a few beers but we got all four broken free and cleaned up.
I lube all four of my swivel eyes twice a year. Completely remove > swivel the eye so nasty black grease is applied to the entire eye surface. Reposition the eye into its normal position - wipe down to remove all external grease.
   / Replacement lower lift arms. #5
I bent mine when using the backhoe. They somehow came unhooked and I backed up…$500 later for two😭
   / Replacement lower lift arms. #7
Necro thread, but I figured this might help others.
I bought 2 of these, bolted right up and work great.
Maybe an inch shorter than factory, but $95, so yeah. Of course I replaced both, but even at $190, better than factory at $425 for 1
   / Replacement lower lift arms. #8
If they are straight still you can have the ends cut off and new ends welded on.
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A52577)
2016 INTERNATIONAL...
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2023 Evolution Classic 4 Pro 48V Golf Cart (A53002)
2023 Evolution...
