Replacement for my KL401 loader
   / Replacement for my KL401 loader #1
Vermont2144
DK40 SE
I damaged my loader arm, up by the rear pivot. I called my local dealer and they advised that loader has been discontinued. I am looking to replace the frame- bucket, hoses, pistons are all good.
Are there any newer model loaders that fit?
   / Replacement for my KL401 loader #2
Aftermarket loader venders:
   / Replacement for my KL401 loader #3
How did you break it? Got some pictures? I have the same loader and it would be nice to know where it broke as I do more digging than I should, carefully, but there's always the odd hard hit...
I would either try getting a used one from a wrecker, or get it welded by someone who knows what they are doing.
I would think either would be far cheaper and easier to find than an aftermarket one.
Also have a close look at your loader mount, for cracks and bending.
The NX series and the NS tractors are basically the same size as well, and I wonder if the loader arms are the same distance apart, same side hyd lines? If so I bet you could just bolt one of them on to the loader side mounting plates. All the specs look very close but you'd have to crawl all over one with a tape and see if it would work. Actually if they are slightly wider or narrower, cutting and sleeving the tube that joins the arms together, isn't a big deal to weld.
   / Replacement for my KL401 loader #4
I would think that you could get a whole lot of repairs/welding done for the price of a replacement FEL.
   / Replacement for my KL401 loader #5
Could you post a picture of the damage? From a liability viewpoint, a dealer might not want to suggest repair.
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
Case IH 496 Disk (A59814)
Case IH 496 Disk...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
NEW Woods 6ft Finish Mower (A56436)
NEW Woods 6ft...
MACK GR64F DUMP TRUCK (A59823)
MACK GR64F DUMP...
