Replacement clutch plates? Where to buy them from??
   / Replacement clutch plates? Where to buy them from?? #1
1greenmachine1
Midwest
JD 2305
Can anyone suggest an online store that I can purchase replacement clutch plates that fit a Frontier Model # PR -1184 (Power Rake). I called Ken Sweet, and he did not have anything that would fit.
The John Deere dealer only sales the entire assembly and wants $600. The dealer says JD no longer carries the Frontier Part # 5SPP400755 - Friction Disc .
I believe the Power Rack is made by Harley Rack and is - MODEL TM-8 POWER BOX RAKE
Information on the clutch plates is below
6 -1/8 Outside Diameter
4" Inside Diameter
1" Thick
   / Replacement clutch plates? Where to buy them from?? #2
I don't know if this will help, but used Google and searched the part number, and got this hit. Frontier PR1148 Power Rake OEM Parts lookup - Clutch Assembly (Part 1) All it will cost is a phone call. At least maybe they can steer you in the right direction.
If that doesn't help, maybe a brick & mortar store such as Clutch & Joint, or something similar can get you what you need, since you have the disc measurements.
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
Booster Cables (A59230)
Booster Cables...
2013 HINO 338 26FT BOX TRUCK (A59575)
2013 HINO 338 26FT...
