Replacement Brake Assemblies
/ Replacement Brake Assemblies #1
mikesee
wilmington, de
BX2660, RTV 900, RTV 1140 CXP, B21, KX-018-3, KX 121-4
urrently have Dexter 7k axles and brakes and am planning on complete replacement. My trailer gets used daily with full loads and is subject to DOT inspection. Anyone have experience with other brand brake assebilies such as Tekenoshia ot Nev-R adjust. Really like the idea of self adjustment.
/ Replacement Brake Assemblies #2
Ditch the drums and get disc brakes. Yes, they cost more up front but the upkeep is nothing. I did this to 2 of my 3 trailers. In my opinion 1 axle of disc brakes has 2 to 3 times the stopping power of two axles of drums.
The big benefit is maintaining them. You can visually inspect them without removing a wheel or drum. Pads are $10 from Auto Zone (mine use Chevy truck parts), ect.
Chris
Thanks Chris. I like the concept of disc brakes and will have then in my next trailer for sure. If I were to upgrade to discs from drums about how long would it take a back yard mechanic to do the swap and are there any special tools or techniques I need?
/ Replacement Brake Assemblies #4
Nothing special. If you have done bearings and seals and bleed brakes before you could do it I'm 4 hours easily. I can change a axle over in no time. It's all bolt on stuff.
Chris
/ Replacement Brake Assemblies #5
Have a 20 ft gooseneck with tandem 6k dexter axles with brakes on both axles. Replaced the assemblies with the Nev-R-Adjust from etrailer a few years ago. Everything went on like it should and works like it should, I'd go the same route again if I was in the same position.
/ Replacement Brake Assemblies #6
Ditch the drums and get disc brakes. Yes, they cost more up front but the upkeep is nothing. I did this to 2 of my 3 trailers. In my opinion 1 axle of disc brakes has 2 to 3 times the stopping power of two axles of drums. The big benefit is maintaining them. You can visually inspect them without removing a wheel or drum. Pads are $10 from Auto Zone (mine use Chevy truck parts), ect. Chris
Can you convert to discs on electric setups or just electric over hydraulic?
/ Replacement Brake Assemblies #8
check etrailer for conversion kits.
https://www.etrailer.com/faq-Adding-Electric-Over-Hydraulic-Disc-Brakes.aspx
the discs - brackets- calapers kit is 250- $300 per axle
Disc Brakes Trailer Brakes | etrailer.com
the electric-hydrualic pump kit is about $700
Titan BrakeRite I Plug and Play Electric-Hydraulic Actuator Kit Titan Trailer Brakes T4813102
a brake line kit is about $100
Trailer Brakes Disc Brakes Brake Line Kit Brake Lines Accessories and Parts | etrailer.com
All and all your looking about about $1100 for one axle conversion, about $1400 for both axles.
/ Replacement Brake Assemblies #10
I get the brakes for about $250 per axle. The hydraulic unit I get for $550. Hoses are about $100.
So you can do the conversion on two axles for under $1200 if you shop around.
Chris
Thanks. I pulled the drum on one axle and the brake assembly is worn out. Have about 6k mikes on the trailer over 3 years with heavy use, used a rental business delivery trailer. Looks like assembly replacement will be an annual project so the investment may make sense.
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
2021 CATERPILLAR 300.9D MINI EXCAVATOR (A62129)
2021 CATERPILLAR...
(INOP) 2004 FORD F-350XL SUPER DUTY FLATBED TRUCK (A59823)
(INOP) 2004 FORD...
(INOP) 1991 GMC TOPKICK DUMP TRUCK (A59823)
(INOP) 1991 GMC...
