replacement battery
/ replacement battery #1
Someone took the battery from my Mahindra 475DI tractor and I don't know what the battery number is. Is there someone out there that can tell me what battery I need to buy for a replacement????
Thanks for any help
/ replacement battery #2
You should contact your dealer and they will be able to help you with your battery. :)
Brenda
Customer Relations
Mahindra USA, Inc.
The dealer I purchased the tractor from no longer sells Mahindra tractors and says he does'nt have any information on replacement parts available. The next nearest dealer is over a hundred miles away.
Thanks for the reply but I guess I will just have to try and find something that fits in the battery space on my tractor
/ replacement battery #4
You don't need a dealer for the battery in my opinion. Just measure the space and go to WalMart or TSC and buy one that fits. Then catch the scoundrel that stole yours.:eek:
/ replacement battery #5
I agree, a good quality WalMart battery will work fine, just measure and ensure the terminals are located on the approprate side.
Thanks to everyone that replied. I went to a battery wholesale whse and found a Batt. that would fit with the necessary cranking amps. The new battery is not the same physical size as the original but it fits and does the job.
Thanks again
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2002 48ft. T/A Flatbed Trailer (A61573)
2002 48ft. T/A...
UNUSED WOLVERINE MSG-11-44W-44" GRAPPLE (A64281)
UNUSED WOLVERINE...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
