replacement battery
/ replacement battery #1
Someone took the battery from my Mahindra 475DI tractor and I don't know what the battery number is. Is there someone out there that can tell me what battery I need to buy for a replacement????
Thanks for any help
/ replacement battery #2
You should contact your dealer and they will be able to help you with your battery. :)
Brenda
Customer Relations
Mahindra USA, Inc.
The dealer I purchased the tractor from no longer sells Mahindra tractors and says he does'nt have any information on replacement parts available. The next nearest dealer is over a hundred miles away.
Thanks for the reply but I guess I will just have to try and find something that fits in the battery space on my tractor
/ replacement battery #4
You don't need a dealer for the battery in my opinion. Just measure the space and go to WalMart or TSC and buy one that fits. Then catch the scoundrel that stole yours.:eek:
/ replacement battery #5
I agree, a good quality WalMart battery will work fine, just measure and ensure the terminals are located on the approprate side.
Thanks to everyone that replied. I went to a battery wholesale whse and found a Batt. that would fit with the necessary cranking amps. The new battery is not the same physical size as the original but it fits and does the job.
Thanks again
2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
2022 WIFO WBGS...
FLUID PUMP (A67714)
FLUID PUMP (A67714)
2010 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A66736)
2010 Chevrolet...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
IRanch High-End Tricycle (A64119)
IRanch High-End...
2006 MACK CV713 (A67714)
2006 MACK CV713...
