Replaced HYD. filter??? Weak backhoe
/ Replaced HYD. filter??? Weak backhoe #1
Marchetti
sonoma , ca
1979 Case 580 C
Hey Guys,
After searching and reading the manual, I'm still not 100% sure I know what to do
I bought a 79 580C. Engine Runs strong.
But I'm not really sure what the thing is capable of. never owned anything like this.
The loader can lift the front end off easy.But, it does come back down over night. I can see I have a leaky cyl. That can be fixed.
I'm not sure if The backhoe is working correctly. I know there is a trick to locking it. I can't do that unless I have gravity on my side. (facing downhill)
The Boom tends to drift away from the backhoe when it is hot after a hr of use. Not sure what that is. I have read about putting a gauge on it to see what it says but honestly that's beyond me I think. maybe not.
Also In reverse it makes kind of a whining sound similar to a loose belt. I checked that . not that.
All the filters have been changed Hyd., fuel, oil, air. are there screen that I do not know about. Fluid seems clear.
Yesterday I used it extensively. I was pulling creeping juniper bushes out. runners everywhere. I thought is would tear thru those, but it seemed to struggle. got worse as time passed.
What else
OH , there are 5 levers for the backhoe
2 stabs
one for the bucket
one for the dipper? and one for the boom
Should I be able to operate this simultaneously? Because I cannot. I have to position And kinda stop and start to lets say scrap the ground. I don't think that's right..
Sorry it long but nowhere else to turn.
thanks
/ Replaced HYD. filter??? Weak backhoe #2
It's probably operating normally for a backhoe of that age. The spool valves will have some wear which will let the cylinders drift slowly even if the cylinder seals are good. Can you raise the rear tires off the ground with the stabilizers, and will it stay up for a while? If so then you're probably doing fine.
With a backhoe that runs off only one pump you can't operate more than one function at a time unless you feather the valves. The whole flow will go to the easiest to move cylinder unless you close that valve part way. You will learn how with practice. I could sometimes move three things at a time on my Case 420.
If it gets weak when it heats up, the pump is probably worn. You should measure the pressure cold and hot at idle and at a higher rpm.
/ Replaced HYD. filter??? Weak backhoe #3
On my Case 580B I had I could operate the boom, dipper, bucket and swing at the same time. As far as locking the boom back, when the boom is almost all the way back, quickly push the lever the other way forward then back to neutral and the boom will travel back the extra distance needed. I know it doesn't make any sense that it would work that way but that's how it's done.
Thanks. Altgough I now have two different answers to simultaneous function. Where di I put a pressure gauge?
So guys where can I test the pressue from? Anyone know?
/ Replaced HYD. filter??? Weak backhoe #6
You can disconnect a hose that goes to a cylinder at the valve and screw the gauge in instead. Actuate the valve and read the pressure.
All the gauges I saw were 1/4 npt. Its gonna be a weird adapter. I thought there was a specific place? Wrong?
Thx
/ Replaced HYD. filter??? Weak backhoe #8
Thx
You need a hydraulic gauge (about 5000 psi rating) and a short hydraulic hose for this. One end of the hose should be adapted to connect the gauge, the other end should match the fitting on the hose you remove. DO NOT USE LOW PRESSURE GAUGE, HOSE OR FITTINGS FOR THIS.
Understand before you proceed that used backhoes will require maintenance. Some of these repairs can be rather involved but can be done if you take the time to learn about it..
Thx. I might let a pro do it
Ine other question I can't seem to find the lift capacity in lbs for the loader. 3000, 4000?? less more?
Thanks again for your help
/ Replaced HYD. filter??? Weak backhoe #10
If it gets worse as the oil heats up it is almost always a pump. These units usually have 2 circuit pumps on them. I would get a hydraulic flow tester or pay somebody to test it for you. It will save you a lot of headaches. CJ
/ Replaced HYD. filter??? Weak backhoe #11
Just my opinion.....
You buy a 38 year old backhoe in rough shape and do not see yourself turning wrenches on it. Honestly you should not have bought this machine. I recommend you sell it now before putting more money in it. You may lose a little money this way, maybe not but keeping this backhoe and paying others to work on it is surely a loosing proposition even if it was given to you.
Evidently you are not comfortable with hooking up a gauge and hose and would let a pro do it. I rest my case.
/ Replaced HYD. filter??? Weak backhoe #12
Lift to full height measured at pins is 3,000 lbs. So you would have to deduct the weight of the bucket from this amount.
/ Replaced HYD. filter??? Weak backhoe #13
That sounds a little mean, but I have to agree with you. Old machines need constant maintnance so you'll be working on it often & needing to be troublesooting wierd problems often.
I borrowed a friends 40 year old hoe. Impressive that hunk of junk was still kicking & being useful. Pins had a quarter inch of slop in them, lots of leaks of various fluids. It did good work, but needed frequent maintnance had lots of quirks & things that were close to failure.
/ Replaced HYD. filter??? Weak backhoe #14
Yeah it may sound a little mean but it is the truth in my opinion. I am not always politically correct and do not want to tell someone what they want to hear. If he wants to learn about this equipment and is willing to try then I am willing to help whatever way I can as a lot of other posters would do.
If you won't try to hook up a hose connection on an old fixer upper backhoe then you should not have bought it. The repair bills forthcoming should be applied to the cost of a new or newer backhoe. Just my opinion.
I feel that what I said is less offensive than pouring money into an old machine only to find it does not increase the value much if any. BTDT in the past, learned my lesson the hard way--financially.
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
Kuhn FC400RG (A60462)
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
