Replaced fuel pump now won't run J/Dere
   / Replaced fuel pump now won't run J/Dere #1
rayikeo2
Platinum Member
I have a LX279 John Deere mower. The fuel pump started leaking out of a vent hole. It was running good except for the leak which was dripping on the muffler cover. I replaced the fuel pump with a new pump and It started right up ran for about 30 seconds and acted like it ran out of gas but the tank was full. I don't have a Tech Manual to referance so I need some advice from some of you with more experiance. Can you give me some ideas to check or point me to some information on the net or anywhere so I can get this mower running again. My grass is getting high. Thanks
Since none of you could or would help me after a lot os searching the internet working and cussing I fixed it my self without your help. Next time I will find a new forum to try for help.......:rolleyes:
   / Replaced fuel pump now won't run J/Dere #3
Gee, talk about sour grapes!
Maybe, just maybe, NO ONE here has ever had the same problem you did!
Adios-good riddens:D
   / Replaced fuel pump now won't run J/Dere #4
WOW !!I guess you really had a bad day.I find you will be hard pressed to find a forum with this much knowledge.Good luck to you.coobie
   / Replaced fuel pump now won't run J/Dere #6
Let's see, ran in, now doesn't run. Must be something you did. Start by checking fuel pressure and volume. No fuel coming out of pump? Check for air leaks on feed side. Loose connections on supply side could be drawing air instead of fuel. You should be able to feel a suction on the supply side of the pump. Also, make sure you have fuel in the tank! (don't ask me how I learned this)
I could have used that information earlier.:cool:
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A53426)
2023 MAXEY G8X...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
2007 Toyota Tundra 4WD Pickup Truck (A53117)
2007 Toyota Tundra...
1275 (A50490)
1275 (A50490)
2005 Kubota M105S (A50123)
2005 Kubota M105S...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
