Replaced fuel pump now won't run J/Dere
   / Replaced fuel pump now won't run J/Dere #1
rayikeo2
Platinum Member
I have a LX279 John Deere mower. The fuel pump started leaking out of a vent hole. It was running good except for the leak which was dripping on the muffler cover. I replaced the fuel pump with a new pump and It started right up ran for about 30 seconds and acted like it ran out of gas but the tank was full. I don't have a Tech Manual to referance so I need some advice from some of you with more experiance. Can you give me some ideas to check or point me to some information on the net or anywhere so I can get this mower running again. My grass is getting high. Thanks
Since none of you could or would help me after a lot os searching the internet working and cussing I fixed it my self without your help. Next time I will find a new forum to try for help.......:rolleyes:
   / Replaced fuel pump now won't run J/Dere #3
Gee, talk about sour grapes!
Maybe, just maybe, NO ONE here has ever had the same problem you did!
Adios-good riddens:D
   / Replaced fuel pump now won't run J/Dere #4
WOW !!I guess you really had a bad day.I find you will be hard pressed to find a forum with this much knowledge.Good luck to you.coobie
   / Replaced fuel pump now won't run J/Dere #6
Let's see, ran in, now doesn't run. Must be something you did. Start by checking fuel pressure and volume. No fuel coming out of pump? Check for air leaks on feed side. Loose connections on supply side could be drawing air instead of fuel. You should be able to feel a suction on the supply side of the pump. Also, make sure you have fuel in the tank! (don't ask me how I learned this)
I could have used that information earlier.:cool:
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53473)
NEW 2025 Load...
2025 JMR Stump Bucket Skid Steer Attachment (A51691)
2025 JMR Stump...
TOTE OF CONCENTRATED METAL CLEANER WITH HOSE AND DIAPHRAM PUMP (A53843)
TOTE OF...
2025 K4525 UNUSED Double Garage Steel Barn (A53117)
2025 K4525 UNUSED...
