Replace oil sending switch?
/ Replace oil sending switch? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
ok, I'll fess up to my boneheaded move.
We have an International 444 (though that doesn't matter for this conversation)
I was carrying a large branch with my backhoe the other day (JCB) and the branch was longer than expected. It brushed agasint the tractor and snapped the oil filter (old canister type, not spin on) holder.
I took that as a good omen since I'd been wanting to update this tractor to a spin on filter for years. Replacement cost is $50 either way so I did it.
Just now installed the new filter holder... noticed something else broken. Turns out it's the sending switch with a 90 degree bend in it, and a slit along its length.
I didn't notice the slit until I fired the tractor up and had oil blowing everywhere under pressure :rolleyes:
I don't know/care how much a sending switch is going to cost me BUT... this tractor is over 30 years old, NONE of the dash items work at all except for the tach which works poorly (or the tractor won't get up to full RPM's)
This has something like a 1/4" threaded tip on it and I'm thinking, why even bother replacing it when I can just buy a plug at NAPA or somewhere and close the hole off?
I personally don't see any issues with doing that but since I'm not any kind of mechanic, figured I'd ask the experts.
Do I:
a) ante up & replace sending unit with new one, pay for part, postage and not have it ever tell me anything useful
b) chunk it in the trash and plug the hole
I vote B
/ Replace oil sending switch? #2
Why not take the fitting to your local tractor supply house and get a gauge to screw into the hole,that will stop the leak and allow you to keep your eye on engine status?
I would if ANY of the engine information lights/gauges on the dash. I don't want to spend anything on something that's not going to work anyway after I 'fix' it.
Most of the electrical items on this tractor don't work
oh... I see I forgot to mention something... walking into house, my hands were covered in oil. I washed them. When I was done washing them, I could NOT find the part anywhere. It seems to have grown legs and wandered off.
I was going to take it to store and match it for a plug and now I don't have it.
Further update, I just hung up with a dealer in Nashville and they told me this was a 1/8" pipe thread which is what I was looking for (presuming it's accurate!)
/ Replace oil sending switch? #5
you could replace it with a mechanical gauge instead of a plug. that way you would see your oil pressure drop the next time you break the fiter off ;) a plug wouldnt hurt anything but a mechanical gauge is pretty cheap and would be better.
/ Replace oil sending switch? #6
If there is something you need to have working on a tractor is a oil pressure gauge and temp gauge and those are available at car part stores and are relatively inexpensive you can buy them with the fittings and tubing included.
You would spend more on a blown engine.
/ Replace oil sending switch? #7
I totally agree with the two posts above. Go to a good parts store and buy a guage set. The cost should be about $60 and with a little time you could install these and keep tabs on your engine.
Ya'll must own stock in Autozone..... ;)
I bought a plug tonight. I'll get it in so I can get some work done. I'll look into the other stuff when my company leaves.
I promise... :)
Sky Jack SJ8831RT 4x4 Rough Terrain Scissor Lift (A61572)
Sky Jack SJ8831RT...
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
2016 Hyundai Sonata Sedan (A61574)
2016 Hyundai...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 Freightliner M2 106 Crew Cab Dump Truck (A61573)
2015 Freightliner...
