replace ignition switch kubota b2710
/ replace ignition switch kubota b2710 #1
gino45
Hawaii
kubota b7100
Okay, I have a shot ignition switch in my b2710 (very similar to b2910 or b7800).
I have a new switch; however, I'm unable to access the backside of the panel. I think that I may need to remove the throttle lever to loosen the black rubber panel behind the gauge panel (sorry if I'm not using the correct terms). The lever appears to be the only thing keeping me from moving the cover, and it seems to be held in place by a pin or I'm not sure what? Not knowing what to do, I just need help knowing what to do to access the inside.
I'm afraid that I might do some damage here, soI stopped. I noticed 2 little slots at the top of the gauge panel. If I could pop that off that might give me access, but it doesn't want to 'pop'. Again, dealing with plastic parts and not wanting to damage anything in the process of accessing the inside of the compartment.
So perhaps some of you gents have some experience with this, either on a b2710 or similar tractor. Help would be appreciated!
Gino
/ replace ignition switch kubota b2710 #2
I'll check the service manual tomorrow, I've got the same tractor.
2016 CATERPILLAR 259D SKID STEER (A64279)
2016 CATERPILLAR...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
Case IH 950 Planter (A63688)
Case IH 950...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
1995 John Deere 7400 (A60462)
1995 John Deere...
