REPLACE ALL?
/ REPLACE ALL? #1
tennis
New Hampshire
Kubota BX23TLB
After my 50 hr service which was done at 28 hours because the tractor is a year old. Just mowing no snow removal last year. I asked the tech. to listen to the mower deck when it's enguaged to me it sounded loud. I was told one of the blades are bent? They all looked the same to me. So I called the dealer to inquire which blade needs to be replaced? They said I have to replace all 3? Does this make sence or has anyone elce experienced this? We all ding a stump,root or rock from time to time this could be a costly fix each time.
/ REPLACE ALL? #2
tennis, did you ask why? Based upon the information you supplied, this doesn't make sense, particularly given the number of hours on the tractor. 28 hours isn't a lot of time spent mowing. If you have them replace all three, I would certainly ask for the old blades back.
/ REPLACE ALL? #3
I'd ask for them back, sharpen them myself and use a balancer. You can pick one up at NAPA. 28 hours isn't enough unless you got one heck of a ding on each of them.
/ REPLACE ALL? #4
Take off the blades and stack them. That can tell you if one is bent. If not follow the previous advice. The blades are pretty hard to bend. Also make sure all is greased properly and any gear boxes have oil in them.
Egon
/ REPLACE ALL?
Thank you all... I did not have them replaced. I like the stack, sharpen and re-ballance option first. I can't recall a huge ding that would of caused any major bend. Thanks again and have a nice holiday. Mike
/ REPLACE ALL? #6
I am not sure I would know if my deck is louder than normal. Amyway, I wouldn't trust such shotty diagnostics. WHat a great opportunity to get aquainted with the bottom of your deck. At the cost of these 60" decks, they should be (and I believe are) capable of plenty of use/abuse without a problem. Have you greased all of the fittings (including universals)?
/ REPLACE ALL? #7
The only reason I could think to replace all at the same time is if you sharpen two, they may not weigh the same as the new one. Wheather that makes a difference, I don't know.
/ REPLACE ALL? #8
Maybe the blades are only sold in sets of three. I have never tried to buy one blade at a time. Whenever I have replaced blades on a multiple blade deck I have always bought a set of three. I have hit some objects pretty hard with both John Deere and Kubota blades and never bent one. They are very tough blades. If I did bend one I would buy a set of three and use the two good used blades as spares in case I ever bent one again. Another thing to keep an eye on is the cupped washers between the blade and spindle. They keep tension on the blades and if they become flattened the blade can slip. I have never had this happen to me but I suppose if it did it might make a strange noise. I think I would check the blades for straitness as mentioned in an earlier post and if they are not bent I would look for something else. Maybe a vibration from a loose grass deflector or something like that. Unless the dealership actually did a thorough examination of your mower deck I would say they are making a guess as to the cause of your noise. Be very careful if you are trying to find the noise with the deck running. Reminds me of an old saying. (Now you see it, now you don't). /w3tcompact/icons/wink.gif
/ REPLACE ALL? #9
I had to get 3 new blades for my BX. I hit a tow truck chain while mowing and tore them up pretty good. You can get them single if you want.
1988 Jeep Wrangler Sahara (A64119)
1988 Jeep Wrangler...
Mini Skid Steer (A60352)
Mini Skid Steer...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
