repairing cracked plastic
/ repairing cracked plastic #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
I have a crack in the plastic cover of the operating console where ones feet rest ~ right over the transmission. Is there some material available today to fix a plastic crack? It seems like there ought to be.. some adhesive or epoxy that could fix this.
/ repairing cracked plastic #2
I have used epoxy to fix a hole in the plastic end cap on my radiator. No leaks yet. A parts store will have epoxy for different applications. Just read the instructions till you find what you need.
/ repairing cracked plastic #3
There are many different kinds of plastic. Some can be melted back together using a solder gun. Some can't be repaired at all. Some use specific adhesives specially formulated. Those home builders stores have a limited selection. My first choice is the local professional automotive paint supply store. The folks there might be able to identify the type of plastic, and therefore, the correct adhesive.
Good luck.
/ repairing cracked plastic #5
There is a post titled " How to fix crack in plastic fender". There was a lengthy discussion on this matter. I gave detailed info on how to fix plastic. I don't know how to set up a link for this post.
/ repairing cracked plastic #6
</font><font color="blue" class="small">( J B weld )</font> JB weld may work to bond some plastics. You will not get a repair that is undetectable like you will when you use the proper repair material and procedure. If I knew how to link to the other post, it will explain everything needed to make a proper repair.
no luck finding it.. anyone have it archived?
/ repairing cracked plastic #8
I have typed in the exact title in the search box with no luck. I have it saved my favorites as "How to fix crack in plastic fender" so I assumed that was the title of the post. Go figure /forums/images/graemlins/confused.gif
/ repairing cracked plastic #11
Believe it or not they make plastic welders. The method is similar to tig welding in that you have a heat source and a filler stick. As much as I hate to suggest it, try looking at Harbor Freight.
Plastic Welder
Depending on the type of plastic, you can also try straight MEK. Just dab it on the crack and let it wick itself in. The cracked edges need to be in contact until the MEK evaporates for it to work.
My experience with epoxy on plastic is that it does not stick. However, there may be a formulation specifically for plastic.
/ repairing cracked plastic #13
</font><font color="blue" class="small">( <font color="blue"> You will not get a repair that is undetectable like you will when you use the proper repair material and procedure. </font> )</font>
Well, I am speaking from my own experience....I have repaired cracked hoods and fenders on my JD 4000 series and I could not disagree more with what you say (based on my experience)
/ repairing cracked plastic #14
</font><font color="blue" class="small">( </font><font color="blueclass=small">( <font color="blue"> You will not get a repair that is undetectable like you will when you use the proper repair material and procedure. </font> )</font>
Well, I am speaking from my own experience....I have repaired cracked hoods and fenders on my JD 4000 series and I could not disagree more with what you say (based on my experience) )</font> <font color="black"> Please let me say this as politely as I can. I am sure I could find every one of your repairs and I am sure no one could find any of my repairs. </font>
/ repairing cracked plastic #15
If a guy is looking for a thrifty way to fix a part rather than replace it, I think a good solid repair that can be seen is going to be quite alright. If I break the hood or fender on my 3720, I'd probably replace it due to the value of the machine...
/ repairing cracked plastic #16
</font><font color="blue" class="small">( <font color="blue"> Please let me say this as politely as I can. I am sure I could find every one of your repairs and I am sure no one could find any of my repairs.
</font> )</font>
Say it however you like...I am not easily intimidated.....you would need a microsocpe to detect any evidence of a repair where I use JB weld to repair plastic. /forums/images/graemlins/smirk.gif
/ repairing cracked plastic #17
</font><font color="blue" class="small">( </font><font color="blueclass=small">( <font color="blue"> Please let me say this as politely as I can. I am sure I could find every one of your repairs and I am sure no one could find any of my repairs.
</font> )</font>
Say it however you like...I am not easily intimidated.....you would need a microsocpe to detect any evidence of a repair where I use JB weld to repair plastic. /forums/images/graemlins/smirk.gif )</font> <font color="black"> Yeh, and I can repair a fine piece of china with contact cement so no one could find it. You may need a microscope but I guarantee I would not. No one can fix a crack in plastic with JB Weld well enough that I could not see it with the naked eye. I started in the autobody repair business 30 years ago. My hands and fingers are so sensitive I could find the repair with my eyes closed. Period, end of story. My last post on this subject. </font>
/ repairing cracked plastic #18
</font><font color="blue" class="small">( <font color="blue"> No one can fix a crack in plastic with JB Weld well enough that I could not see it with the naked eye. I started in the autobody repair business 30 years ago. My hands and fingers are so sensitive I could find the repair with my eyes closed. </font> )</font>
Ahhhh....yeah......right on all 3......
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2011 Chevrolet Silverado Pickup Truck (A62613)
2011 Chevrolet...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
Electric Transfer Pump w/Tank (A64127)
Electric Transfer...
