Dwilson540
- Joined
- May 14, 2020
- Messages
- 32
- Tractor
- Kubota L4200
I have a L4200, probably built in 1998 or so. It has a cab. Are these aftermarket? It is Kubota orange and I see a roll over placard that says Kubota behind the seat, but I don't know if that is just the rollover, or the cab. Any ideas of where to look for cab mfg. info? Here's the problem I think the ac clutch went out. It is a Denso compressor. Easy enough to repair. But the bottom pulley that powers the ac looks like someone chewed off the outer flange. What could cause that? Obviously the belt failed as well. How hard of job will it be to change out that pulley? If I take off the radiator, can I get enough access to it that way? My ChatGPT, which frequently doesn't have a clue, tells me that normally Kubota pulleys are held in place with keys, not splines. And is asking if this spline or pulley is bolted on to the pulley behind it, that I assume drives the generator and water pump. Anyone know?
