Renault Super 7
   / Renault Super 7 #1
sargex595
New York / Vermont Border
John Deere X595
My neighbor acquired an older Renault Super 7 tractor that needs some work. He needs a head gasket to get started. Does anyone know where he might get information and parts for this tractor?
   / Renault Super 7 #2
I don't know about parts but there are places out there that will make a head gasket if you send them the old one.
   / Renault Super 7 #3
Write the French Embassy.
No, I'm not kidding. A friend of mine who had a similar problem with an obscure Italian engine wrote the Italian Embassy. A few weeks later he got a cordial letter back from them telling him where he could get parts.
   / Renault Super 7 #4
Many years ago, I can remember my Dad buying gasket material at a local auto parts store and cutting his own gaskets. Don't ask me if they were head gaskets or not, I was a small child, can't remember what gaskets he cut or what they were for. I believe he placed the old gasket over the material and traced it, then cut it.
   / Renault Super 7 #5
You can place gasket material over the block and tap it with a hammer to transfer the cylinder outlines to the material.
   / Renault Super 7 #6
Most replacement head gaskets for old equipment are made of copper with a fiber filler. The copper will help eliminate any minor irregularities in the head or block.
   / Renault Super 7 #8
Renault used either a Perkins, Deutz or MWM engine.
Perkins is available through Caterpillar as they own the place nowadays.
MWM is available through Deutz, also because Deutz owns it.
Deutz should be available anywhere in the world as it is a very common industrial engine.
   / Renault Super 7 #9
Deutz only in the vineyard and orchard tractors. Perkins, Indenor, Renault and MWM for sure.
Super 7 is 3cyl. Perkins with 42 hp.
   / Renault Super 7 #10
that's correct, but in the era of the super 7, Renault didnt build any tractor engines anymore, and Indenor ?? was long gone. :p
   / Renault Super 7 #11
I disagree
The Super 7 was introduced in around 1962 and had the oldfashioned hood, we have had the same one. Indenor Diesel was in the Super 2 D (internal Code R7201). The Super 2 D was built from 1967 to 1969.
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
2010 Case 580N (A60462)
2010 Case 580N...
4ft Mini Skid Quick Attach Rotary Cutter (A61306)
4ft Mini Skid...
2012 John Deere 6170R (A57148)
2012 John Deere...
