Removing wheel hub on JD 155C
   / Removing wheel hub on JD 155C #1
PArnold993
Grass Valley CA
JD 155C
I need to remove a front wheel for a tire repair. The cap protecting the hub is a flexible plastic, and should come off easily, but not for me. I have tried with hands, with channel lock pliers, and small pry bar. Nothing works. Can somebody give me the secret?
   / Removing wheel hub on JD 155C #2
I use a lady slipper to get behind it and work plastic over the washer. Worse case cut it off with a utility knife. Caps are about seven bucks. Good luck.
New Kivel Mini Skidloader Pallet Forks (A50775)
New Kivel Mini...
2015 JOHN DEERE GATOR TURF UTV (A51406)
2015 JOHN DEERE...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
(80) 2" X 2" X 8' ANGLE IRON (A54756)
(80) 2" X 2" X 8'...
